[postgis-tickets] [PostGIS] #5316: Regress failure with in-develop proj
PostGIS trac at osgeo.org
Mon Jun 19 07:26:01 PDT 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 Sadly changes did not fix 3.3.10, because PROJ 5.2 still errors out.
 https://github.com/postgis/postgis/actions/runs/5312510774/jobs/9617110243
  ./regress/core/regress_proj_cache_overflow .. failed (diff expected
 obtained: /tmp/pgis_reg/test_61_diff)
 --- ./regress/core/regress_proj_cache_overflow_expected 2023-06-19
 13:30:42.000000000 +0000
 +++ /tmp/pgis_reg/test_61_out   2023-06-19 13:32:56.056377261 +0000
 @@ -1 +1 @@
 -13|112
 +ERROR:  transform: latitude or longitude exceeded limits (-14)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5316#comment:17>
