[postgis-tickets] [PostGIS] #5316: Regress failure with in-develop proj
PostGIS trac at osgeo.org
Mon Jun 19 08:19:56 PDT 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by strk):
 Environment variables used by libproj are here:
 https://proj.org/en/9.2/usage/environmentvars.html
 There seem to be a variable to disable network and one to set proj data.
 For the sake of tests predictability I think we should set network off and
 point PROJ_DATA to an empty directory or similar
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5316#comment:19>
