[postgis-tickets] [PostGIS] #5372: macOs CI: cannot build with topology
PostGIS trac at osgeo.org
Mon Jun 19 08:55:59 PDT 2023
  Reporter:  lbartoletti  |      Owner:  lbartoletti
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:  Website Management, Bots
 Component:  topology     |    Version:  3.3.x
Resolution:               |   Keywords:  macos, ci
Comment (by pramsey):
 I can build and regress fine on MacOS here, so this is a CI issue rather
 than a code issue (or a code mixed with CI env issue). In any event, if
 you want to fix it, please do, and reopen this ticket with a patch, I'll
 be happy to test locally and apply it if you have a solution.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5372#comment:7>
