[postgis-tickets] [PostGIS] #5316: Regress failure with in-develop proj
PostGIS trac at osgeo.org
Mon Jun 19 13:18:21 PDT 2023
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"2d77093c8ea69c4a38a26f023d6caa9e3eac02b5/git" 2d77093/git]:
 {{{#!CommitTicketReference repository="git"
 revision="2d77093c8ea69c4a38a26f023d6caa9e3eac02b5"
 Remove entries that cause
 errors in Proj 5.2 and 4.9
 References #5316 for PostGIS 3.3.4
 Namely:  transform: latitude or longitude exceeded limits (-14)
  transform the point because either no grid shift files were found
   failed to load datum shift file (-38)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5316#comment:21>
