[postgis-tickets] [PostGIS] #5254: address standardizer install-check is broken
PostGIS trac at osgeo.org
Mon Jun 19 13:23:00 PDT 2023
  Reporter:  robe                 |      Owner:  strk
      Type:  defect               |     Status:  closed
  Priority:  blocker              |  Milestone:  PostGIS 3.4.0
 Component:  pagc_address_parser  |    Version:  master
Resolution:  fixed                |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"e6d6be316631881e464778e958b94cda1c270348/git"
 e6d6be31/git]:
 {{{#!CommitTicketReference repository="git"
 revision="e6d6be316631881e464778e958b94cda1c270348"
 Restore 'installcheck' support for address_standardizer
 Closes #5254
 Update expected result as trailing blanks were missing
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5254#comment:2>
