[postgis-tickets] [PostGIS] #5387: ST_Transform(geom, str, str) is very slow
PostGIS trac at osgeo.org
Mon Jun 19 13:43:48 PDT 2023
  Reporter:  cdestigter  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.4.0
 Component:  postgis     |    Version:  3.3.x
Resolution:              |   Keywords:
Comment (by cdestigter):
 Yes - but it doesn't make sense to have to sync up the SRIDs in that table
 with the systems in proj.db. Apart from any other concerns, we'd have to
 find and use some form of integer IDs for them - and not all of them are
 EPSG CRSes. In addition the Postgres database is not deployed concurrently
 with the proj.db in our app images and so trying to keep them in sync
 would require complex migrations, which can be avoided if we skip using
 spatial_ref_sys at all.
 I feel like that concern is tangential - the issue I had in this ticket is
 that some forms of the ST_Transform() function are very slow - presumably
 they are not caching their transforms across multiple input rows. Can this
 be improved?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5387#comment:8>
