[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-987-gf86792b86
Tue Jun 20 01:03:28 PDT 2023
the project "PostGIS".
       via  f86792b860f07adf71cef551e227924e0938a305 (commit)
       via  1c2743b359791cbd9cb09c0c17da77774b144086 (commit)
      from  80945f8d23c4e21852105416b394e4f817ab0653 (commit)
revisions in full, below.
commit f86792b860f07adf71cef551e227924e0938a305
Merge: 80945f8d2 1c2743b35
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jun 20 01:03:26 2023 -0700
    Merge pull request 'Fix typo in ST_SetM documentation' (!125) from tmuguet/postgis:master into master
    Reviewed-on: https://git.osgeo.org/gitea/postgis/postgis/pulls/125
commit 1c2743b359791cbd9cb09c0c17da77774b144086
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date:   Tue Jun 20 09:19:46 2023 +0200
    Fix typo
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index 64cfcb681..c0f3c2b55 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -5285,7 +5285,7 @@ FROM test_raster
         <refentry id="RT_ST_SetM">
             <refnamediv>
                 <refname>ST_SetM</refname>
-                <refpurpose>Returns a geometry with the same X/Y coordinates as the input geometry, and values from the raster copied into the Z dimension using the requested resample algorithm.</refpurpose>
+                <refpurpose>Returns a geometry with the same X/Y coordinates as the input geometry, and values from the raster copied into the M dimension using the requested resample algorithm.</refpurpose>
             </refnamediv>
             <refsynopsisdiv>
@@ -5303,7 +5303,7 @@ FROM test_raster
             <refsection>
                 <title>Description</title>
-                <para>Returns a geometry with the same X/Y coordinates as the input geometry, and values from the raster copied into the Z dimensions using the requested resample algorithm.</para>
+                <para>Returns a geometry with the same X/Y coordinates as the input geometry, and values from the raster copied into the M dimensions using the requested resample algorithm.</para>
                 <para>The <varname>resample</varname> parameter can be set to "nearest" to copy the values from the cell each vertex falls within, or "bilinear" to use <ulink url="https://en.wikipedia.org/wiki/Bilinear_interpolation">bilinear interpolation</ulink> to calculate a value that takes neighboring cells into account also.</para>
                 <para>Availability: 3.2.0</para>
Summary of changes:
 doc/reference_raster.xml | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
