[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-988-g9ec3f4bc5
Tue Jun 20 06:52:59 PDT 2023
the project "PostGIS".
       via  9ec3f4bc526e44bc2e2afa530f5cc8cf238d366a (commit)
      from  f86792b860f07adf71cef551e227924e0938a305 (commit)
revisions in full, below.
commit 9ec3f4bc526e44bc2e2afa530f5cc8cf238d366a
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jun 20 10:46:32 2023 +0200
    Allow building commandline tools without PostgreSQL
    Closes #5177
    Have woodie guard after this
diff --git a/.woodpecker/tools.yml b/.woodpecker/tools.yml
new file mode 100644
index 000000000..5c3a417f2
--- /dev/null
+++ b/.woodpecker/tools.yml
@@ -0,0 +1,13 @@
+pipeline:
+  build:
+    image: docker.osgeo.org/postgis/build-test:trisquel3
+    commands:
+      - ./autogen.sh
+      - ./configure --without-pgconfig --prefix=/tmp/pgx
+      - make
+      - make check
+      - make install
+      - /tmp/pgx/bin/postgis help
+      - /tmp/pgx/bin/shp2pgsql
+      - /tmp/pgx/bin/raster2pgsql
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 34afbc372..7e8b1a698 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -4,9 +4,9 @@
-SUBDIRS = liblwgeom
+SUBDIRS = liblwgeom @RASTER@ loader
 ifeq (@LIBLWGEOM_ONLY@,no)
-SUBDIRS += @DEPS_SUBDIR@ libpgcommon postgis regress @RASTER@ @TOPOLOGY@ @SFCGAL@ loader utils doc @EXTENSIONS@
+SUBDIRS += @DEPS_SUBDIR@ libpgcommon postgis regress @TOPOLOGY@ @SFCGAL@ utils doc @EXTENSIONS@
 endif
 HAVE_SFCGAL=@HAVE_SFCGAL@
@@ -65,7 +65,11 @@ clean-local:
 # TODO: drop 'test' target..
 test: check
-check: check-no-trailing-blanks check-unit check-regress docs-check check-news check-tests-enabled
+check: check-no-trailing-blanks check-unit docs-check check-news check-tests-enabled
+ifeq (@LIBLWGEOM_ONLY@,no)
+check: check-regress
+endif
 staged-install: all
 	$(MAKE) -C regress staged-install
diff --git a/configure.ac b/configure.ac
index b673cca3d..ae7a4bb08 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1483,9 +1483,12 @@ if test "x$with_raster" != "xno"; then
 		CPPFLAGS_SAVE="$CPPFLAGS"
 		CPPFLAGS="$LIBGDAL_CFLAGS"
 		CFLAGS_SAVE="$CFLAGS"
-		CFLAGS=`"$PG_CONFIG" --cflags`
 		CC_SAVE="$CC"
-		CC=`"$PG_CONFIG" --cc`
+		if test "x$PG_CONFIG" != "xno"; then
+			CFLAGS=`"$PG_CONFIG" --cflags`
+			CC=`"$PG_CONFIG" --cc`
+		fi
 		LIBS_SAVE="$LIBS"
 		LIBS="$LIBGDAL_LDFLAGS"
@@ -1521,9 +1524,11 @@ if test "x$with_raster" != "xno"; then
 	dnl Define raster objects, for makefiles
 	RT_CORE_LIB=corelib
-	RT_PG_LIB=pglib
 	RT_LOADER=rtloader
-	RT_POSTGIS_SQL=rtpostgis.sql
+		RT_PG_LIB=pglib
+		RT_POSTGIS_SQL=rtpostgis.sql
+	fi
 	AC_SUBST([RASTER])
 	AC_SUBST([RT_CORE_LIB])
@@ -1709,14 +1714,16 @@ dnl the xlstproc tool for generating the comments SQL file.
 dnl ===========================================================================
 EXTENSIONS=""
-if test \
-        "x$XSLTPROC" != "x" -o \
-        -e doc/postgis_comments.sql -a \
-        -e doc/raster_comments.sql;
-then
-    AC_MSG_RESULT([enabling PostgreSQL extension support...])
-    EXTENSIONS=extensions
-    AC_SUBST([EXTENSIONS])
+if test "x$PG_CONFIG" != "xno"; then
+  if test \
+          "x$XSLTPROC" != "x" -o \
+          -e doc/postgis_comments.sql -a \
+          -e doc/raster_comments.sql;
+  then
+      AC_MSG_RESULT([enabling PostgreSQL extension support...])
+      EXTENSIONS=extensions
+      AC_SUBST([EXTENSIONS])
+  fi
 fi
 INSTALL_EXTENSION_UPGRADES=yes
diff --git a/loader/Makefile.in b/loader/Makefile.in
index da10b442d..aead6159c 100644
--- a/loader/Makefile.in
+++ b/loader/Makefile.in
@@ -34,9 +34,17 @@ LDFLAGS = @LDFLAGS@
 # Filenames with extension as determined by the OS
 POSTGIS-CLI=postgis
-PGSQL2SHP-CLI=pgsql2shp at EXESUFFIX@
 SHP2PGSQL-CLI=shp2pgsql at EXESUFFIX@
-SHP2PGSQL-GUI=shp2pgsql-gui at EXESUFFIX@
+PGSQL2SHP-CLI=
+SHP2PGSQL-GUI=
+ifneq (@PG_CONFIG@,no)
+	PGSQL2SHP-CLI=pgsql2shp at EXESUFFIX@
+	ifneq (@GTK_BUILD@,)
+		SHP2PGSQL-GUI=shp2pgsql-gui at EXESUFFIX@
+		# We test this variable later to see if we're building the GUI
+		gtk_build = 1
+	endif
+endif
 # PostgreSQL frontend CPPFLAGS and LDFLAGS (for compiling and linking with libpq)
 PGSQL_FE_CPPFLAGS=@PGSQL_FE_CPPFLAGS@
@@ -76,9 +84,6 @@ ifeq ($(REGRESS),1)
 	datadir=/share
 endif
-# We test this variable later to see if we're building the GUI
-gtk_build = @GTK_BUILD@
 # Common object files
 SHPLIB_OBJS = shpopen.o dbfopen.o getopt.o shpcommon.o safileio.o
@@ -143,10 +148,12 @@ ifdef gtk_build
 endif
 install: installdir install-desktop install-icons
-ifdef gtk_build
+ifneq ($(SHP2PGSQL-GUI),)
 	$(LIBTOOL) --mode=install $(INSTALL) $(SHP2PGSQL-GUI) "$(DESTDIR)$(bindir)/$(SHP2PGSQL-GUI)"
 endif
+ifneq ($(PGSQL2SHP-CLI),)
 	$(LIBTOOL) --mode=install $(INSTALL) $(PGSQL2SHP-CLI) "$(DESTDIR)$(bindir)/$(PGSQL2SHP-CLI)"
+endif
 	$(LIBTOOL) --mode=install $(INSTALL) $(SHP2PGSQL-CLI) "$(DESTDIR)$(bindir)/$(SHP2PGSQL-CLI)"
 	$(LIBTOOL) --mode=install $(INSTALL) $(POSTGIS-CLI) "$(DESTDIR)$(bindir)/$(POSTGIS-CLI)"
@@ -161,9 +168,13 @@ ifdef gtk_build
 endif
 uninstall: uninstall-desktop uninstall-icons
 	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(PGSQL2SHP-CLI)"
+endif
 	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(SHP2PGSQL-CLI)"
 	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(SHP2PGSQL-GUI)"
+endif
 	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(POSTGIS-CLI)"
 # TODO: move here what's currently run from regress/loader and
diff --git a/loader/cunit/Makefile.in b/loader/cunit/Makefile.in
index a6f842a73..33a115d0e 100644
--- a/loader/cunit/Makefile.in
+++ b/loader/cunit/Makefile.in
@@ -63,19 +63,27 @@ VPATH = $(srcdir)
 # Object files
 OBJS=	\
-	cu_pgsql2shp.o \
 	cu_shp2pgsql.o \
 	cu_tester.o
+OBJS +=	\
+	cu_pgsql2shp.o
+endif
 LOADER_OBJS= \
 	../dbfopen.o \
 	../shpopen.o \
 	../getopt.o \
 	../shpcommon.o \
 	../safileio.o \
-	../pgsql2shp-core.o \
 	../shp2pgsql-core.o
+LOADER_OBJS +=	\
+	../pgsql2shp-core.o
+endif
 # If we couldn't find the cunit library then display a helpful message
 ifeq ($(CUNIT_LDFLAGS),)
 all: requirements_not_met_cunit
diff --git a/loader/cunit/cu_tester.c b/loader/cunit/cu_tester.c
index d23bde7c5..d47d5b1aa 100644
--- a/loader/cunit/cu_tester.c
+++ b/loader/cunit/cu_tester.c
@@ -13,6 +13,7 @@
 #include <string.h>
 #include "CUnit/Basic.h"
 #include "cu_tester.h"
+#include "../postgis_config.h"
 ** The main() function for setting up and running the tests.
@@ -33,12 +34,14 @@ int main()
 		return CU_get_error();
+#ifdef POSTGIS_PGSQL_VERSION
 	/* Add the pgsql2shp test suite */
 	if (NULL == register_pgsql2shp_suite())
 		CU_cleanup_registry();
+#endif
 	/* Run all tests using the CUnit Basic interface */
 	CU_basic_set_mode(CU_BRM_VERBOSE);
diff --git a/loader/shp2pgsql-cli.c b/loader/shp2pgsql-cli.c
index 149ed55c2..209c0745d 100644
--- a/loader/shp2pgsql-cli.c
+++ b/loader/shp2pgsql-cli.c
@@ -86,9 +86,11 @@ main (int argc, char **argv)
 	int ret, i;
 #ifdef ENABLE_NLS
+#ifdef PGSQL_LOCALEDIR
 	setlocale (LC_ALL, "");
 	bindtextdomain (PACKAGE, PGSQL_LOCALEDIR);
 	textdomain (PACKAGE);
+#endif
 #endif
 	/* If no options are specified, display usage */
diff --git a/raster/Makefile.in b/raster/Makefile.in
index d8a12d0bf..401723346 100644
--- a/raster/Makefile.in
+++ b/raster/Makefile.in
@@ -25,6 +25,8 @@ LDFLAGS = @LDFLAGS@
 all: @RT_CORE_LIB@ @RT_PG_LIB@ @RT_LOADER@ @RT_POSTGIS_SQL@
+with_pg = @RT_PG_LIB@
 corelib:
 	$(MAKE) -C rt_core
@@ -38,28 +40,36 @@ rtpostgis.sql:
 	$(MAKE) -C rt_pg rtpostgis.sql
 install: all
-	$(MAKE) -C rt_pg install
 	$(MAKE) -C loader install
+ifdef with_pg
+	$(MAKE) -C rt_pg install
 	$(MAKE) -C scripts install
+endif
 uninstall:
-	$(MAKE) -C rt_pg uninstall
 	$(MAKE) -C loader uninstall
+ifdef with_pg
+	$(MAKE) -C rt_pg uninstall
 	$(MAKE) -C scripts uninstall
+endif
 clean:
 	$(MAKE) -C rt_core $@
-	$(MAKE) -C rt_pg $@
 	$(MAKE) -C loader $@
 	$(MAKE) -C test $@
+ifdef with_pg
+	$(MAKE) -C rt_pg $@
 	$(MAKE) -C scripts $@
+endif
 distclean: clean
 	$(MAKE) -C test $@
+ifdef with_pg
+endif
 	rm -f raster_config.h Makefile
 check check-unit check-regress core-check:
diff --git a/raster/loader/Makefile.in b/raster/loader/Makefile.in
index 5fc6b6038..250dac361 100644
--- a/raster/loader/Makefile.in
+++ b/raster/loader/Makefile.in
@@ -24,6 +24,9 @@ top_builddir = @top_builddir@
 builddir = @builddir@
 top_srcdir = @top_srcdir@
 srcdir = @srcdir@
+prefix = @prefix@
+exec_prefix = @exec_prefix@
+bindir = @bindir@
 VPATH = $(srcdir)
@@ -86,13 +89,13 @@ $(RASTER2PGSQL): ../rt_core/librtcore.a raster2pgsql.o
 	$(LIBTOOL) --mode=link $(CC) $(CFLAGS) $^ $(LDFLAGS) -o $@
 installdir:
-	@mkdir -p $(DESTDIR)$(PGSQL_BINDIR)
+	@mkdir -p $(DESTDIR)$(bindir)
 install: installdir
-	$(LIBTOOL) --mode=install $(INSTALL) $(RASTER2PGSQL) "$(DESTDIR)$(PGSQL_BINDIR)/$(RASTER2PGSQL)"
+	$(LIBTOOL) --mode=install $(INSTALL) $(RASTER2PGSQL) "$(DESTDIR)$(bindir)/$(RASTER2PGSQL)"
 uninstall:
-	$(LIBTOOL) --mode=uninstall $(RM) "$(DESTDIR)$(PGSQL_BINDIR)/$(RASTER2PGSQL)"
+	$(LIBTOOL) --mode=uninstall $(RM) "$(DESTDIR)$(bindir)/$(RASTER2PGSQL)"
 ../rt_core/librtcore.a:
 	$(MAKE) -C $(buidldir)/../rt_core
diff --git a/raster/test/Makefile.in b/raster/test/Makefile.in
index fd0ae4021..5a8b381fa 100644
--- a/raster/test/Makefile.in
+++ b/raster/test/Makefile.in
@@ -18,8 +18,12 @@ core-check: check-unit
 check-unit:
 	$(MAKE) -C cunit check
 check-regress:
 	$(MAKE) -C regress check
+else
+check-regress:
+endif
 clean:
 	$(MAKE) -C cunit $@
Summary of changes:
 .woodpecker/tools.yml     | 13 +++++++++++++
 GNUmakefile.in            | 10 +++++++---
 configure.ac              | 31 +++++++++++++++++++------------
 loader/Makefile.in        | 23 +++++++++++++++++------
 loader/cunit/Makefile.in  | 12 ++++++++++--
 loader/cunit/cu_tester.c  |  3 +++
 loader/shp2pgsql-cli.c    |  2 ++
 raster/Makefile.in        | 18 ++++++++++++++----
 raster/loader/Makefile.in |  9 ++++++---
 raster/test/Makefile.in   |  4 ++++
 10 files changed, 95 insertions(+), 30 deletions(-)
 create mode 100644 .woodpecker/tools.yml
hooks/post-receive
