[postgis-tickets] [PostGIS] #5267: [Enhacement] Extrapolate Linestring rate and distance support
PostGIS trac at osgeo.org
Tue Jun 20 16:03:41 PDT 2023
  Reporter:  latot        |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.4.0
 Component:  postgis      |    Version:  3.3.x
Resolution:               |   Keywords:
Comment (by pramsey):
 I think line extension is a distraction, since the core operation here (in
 cartesian and geographics) is projection. Basically, a function like
 https://postgis.net/docs/ST_Project.html only with two arguments and a
 distance. You could build it yourself easily enough from parts already
 lying around.
 ST_Project(ST_StartPoint(line), distance, ST_Azimuth(ST_StartPoint(line),
 ST_EndPoint(line))
 There's already functions to get the start/end/nth point of a line, and
 there's already these projection functions (which, conveniently, already
 exist for geometry and geography).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5267#comment:8>
