[postgis-tickets] [PostGIS] #5385: Postgres malloc assertion fail when using pg_cancel_backend with ST_AsMVT
PostGIS trac at osgeo.org
Wed Jun 21 08:47:38 PDT 2023
  Reporter:  gbartonowenstl  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  high            |  Milestone:  PostGIS 3.1.10
 Component:  postgis         |    Version:  3.3.x
Resolution:                  |   Keywords:  malloc, crash
Comment (by pramsey):
 Ah, but we do have independent interrupt handling in wagyu... so a second
 experiment would be: if you comment out all calls to
 `lwgeom_wagyu_interrupt*` in postgis_module.c does the problem go away?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5385#comment:5>
