[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-992-g8fd02bc3a
Wed Jun 21 11:38:13 PDT 2023
the project "PostGIS".
       via  8fd02bc3ac8fe9c96635efd1f32d9ef9ea938bdf (commit)
      from  6cc527c57a8f13936234da6e19fa3062b18bbfb7 (commit)
revisions in full, below.
commit 8fd02bc3ac8fe9c96635efd1f32d9ef9ea938bdf
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jun 21 11:38:02 2023 -0700
    Add metadata about Proj network grids cache to the postgis_proj_version() info string
diff --git a/NEWS b/NEWS
index a6fc1e74e..efc226614 100644
--- a/NEWS
+++ b/NEWS
@@ -28,6 +28,7 @@ xxxx/xx/xx
   - Speed up coincident nodes check in topology validation  (Sandro Santilli)
   - GH718, ST_QuantizeCoordinates(): speed-up implementation (Even Rouault)
   - Repair spatial planner stats to use computed selectivity for contains/within queries (Paul Ramsey)
+  - Additional metadata on Proj installation in postgis_proj_version (Paul Ramsey)
 * Bug Fix *
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index 3d631faa8..105720bb5 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -31,6 +31,7 @@
 #include "../postgis_config.h"
 #include "liblwgeom.h"
 #include "lwgeodetic.h"
+#include "stringbuffer.h"
 #include "lwgeom_transform.h"
@@ -200,14 +201,30 @@ Datum transform_pipeline_geom(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(postgis_proj_version);
 Datum postgis_proj_version(PG_FUNCTION_ARGS)
+	stringbuffer_t sb;
 #if POSTGIS_PROJ_VERSION < 61
-	const char *ver = pj_get_release();
-	text *result = cstring_to_text(ver);
+	stringbuffer_init(&sb);
+	stringbuffer_append(&sb, pj_get_release());
 #else
 	PJ_INFO pji = proj_info();
-	text *result = 	cstring_to_text(pji.version);
+	stringbuffer_append(&sb, pji.version);
+#endif
+#if POSTGIS_PROJ_VERSION >= 70
+	stringbuffer_aprintf(&sb,
+		" PROJ_NETWORK=%s",
+		proj_context_is_network_enabled(NULL) ? "ON" : "OFF");
+	if (proj_context_get_url_endpoint(NULL))
+		stringbuffer_aprintf(&sb, " PROJ_URL_ENDPOINT=%s", proj_context_get_url_endpoint(NULL));
+	if (proj_context_get_user_writable_directory(NULL, 0))
+		stringbuffer_aprintf(&sb, " PROJ_GRID_DIRECTORY=%s", proj_context_get_user_writable_directory(NULL, 0));
 #endif
-	PG_RETURN_POINTER(result);
+	PG_RETURN_POINTER(cstring_to_text(stringbuffer_getstring(&sb)));
Summary of changes:
 NEWS                       |  1 +
 postgis/lwgeom_transform.c | 25 +++++++++++++++++++++----
 2 files changed, 22 insertions(+), 4 deletions(-)
hooks/post-receive
