[postgis-tickets] [PostGIS] #5409: install-check for address_standardizer is broken in 3.3
PostGIS trac at osgeo.org
Fri Jun 23 06:53:34 PDT 2023
  Reporter:  tbussmann  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  low        |  Milestone:  PostGIS 3.3.4
 Component:  postgis    |    Version:  3.3.x
Resolution:             |   Keywords:
Description changed by tbussmann:
Old description:
> commit [722d8873/git] accidentally removed trailing whitespace from
> `/extensions/address_standardizer/expected/test-
> standardize_address_1.out` braking `make install-check` for
> address_standardizer. This was fixed for 3.4 in [e6d6be31/git] but needs
> to be fixed in the stable-3.3 branch, too.
New description:
 `/extensions/address_standardizer/expected/test-standardize_address_1.out`
 braking `make installcheck` for address_standardizer. This was fixed for
 3.4 in [e6d6be31/git] but needs to be fixed in the stable-3.3 branch, too.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5409#comment:3>
