[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1002-g9f61faf5c
Sat Jun 24 18:08:35 PDT 2023
the project "PostGIS".
       via  9f61faf5c2a684f47141a4485fbfac07be4fb090 (commit)
      from  7f823a67b77ed12f738aa260def6c24cebc23717 (commit)
revisions in full, below.
commit 9f61faf5c2a684f47141a4485fbfac07be4fb090
Author: Pierre Cardinal <pierre.cardinal at sympatico.ca>
Date:   Fri Jun 23 19:31:17 2023 +0000
    Translated using Weblate (French)
    Currently translated at 12.4% (226 of 1814 strings)
    Translation: postgis/release_notes.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/release_notesxml/fr/
diff --git a/doc/po/fr/release_notes.xml.po b/doc/po/fr/release_notes.xml.po
index 7f398194f..431039741 100644
--- a/doc/po/fr/release_notes.xml.po
+++ b/doc/po/fr/release_notes.xml.po
@@ -5,13 +5,14 @@
 # Rodolphe Quiédeville <rodolphe at quiedeville.org>, 2013
 # Regina Obe <regina at arrival3d.com>, 2022.
 # Vincent Bre <vincent.bre at oslandia.com>, 2023.
+# Pierre Cardinal <pierre.cardinal at sympatico.ca>, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-05-25 20:53+0000\n"
-"PO-Revision-Date: 2023-05-31 15:08+0000\n"
-"Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
+"PO-Revision-Date: 2023-06-25 01:08+0000\n"
+"Last-Translator: Pierre Cardinal <pierre.cardinal at sympatico.ca>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "release_notesxml/fr/>\n"
 "Language: fr\n"
@@ -1937,6 +1938,8 @@ msgid ""
 "#4933, topology.GetFaceByPoint will not work with topologies having invalid "
 "edge linking."
 msgstr ""
+"#4933, topology.GetFaceByPoint ne fonctionnera pas avec les topologies dont "
+"la liaison des arêtes n'est pas valide."
 #. Tag: para
 #: release_notes.xml:491
@@ -1954,12 +1957,16 @@ msgid ""
 "scale close to target extent. If you need previous simplifying behaviour, "
 "you can ST_Simplify the geometry in advance. (Darafei Praliaskouski)"
 msgstr ""
+"#4149, ST_AsMVTGeom préserve maintenant plus de détails de la géométrie "
+"originale à une échelle proche de l'étendue cible. Si vous avez besoin du "
+"comportement de simplification précédent, vous pouvez utiliser ST_Simplify "
+"sur la géométrie à l'avance. (Darafei Praliaskouski)"
 #. Tag: para
 #: release_notes.xml:495
 #, no-c-format
 msgid "Proj 4.9 or higher is required."
-msgstr ""
+msgstr "Proj 4.9 ou une version plus récente est nécessaire."
 #. Tag: para
 #: release_notes.xml:499
@@ -1968,6 +1975,8 @@ msgid ""
 "#2592, Do not allow CreateTopology to define topologies with SRID > 0 "
 "(Sandro Santilli)"
 msgstr ""
+"#2592, Ne pas autoriser CreateTopology à définir des topologies avec SRID "
+"< 0 (Sandro Santilli)"
 #. Tag: para
 #: release_notes.xml:501
@@ -1975,6 +1984,8 @@ msgstr ""
 msgid ""
 "#3232, Prevent moving an isolated node to different face (Sandro Santilli)"
 msgstr ""
+"#3232, Empêcher le déplacement d'un noeud isolé vers une autre face (Sandro "
+"Santilli)"
 #. Tag: para
 #: release_notes.xml:503
@@ -1983,6 +1994,8 @@ msgid ""
 "Consider collection TopoGeometries while editing topology primitives. "
 "(Sandro Santilli)"
 msgstr ""
+"Considérer la collection TopoGeometries lors de l'édition des primitives "
+"topologiques. (Sandro Santilli)"
 #. Tag: para
 #: release_notes.xml:505
@@ -1991,6 +2004,8 @@ msgid ""
 "#3248, Prevent removing isolated edges if used in a TopoGeometry (Sandro "
 "Santilli)"
 msgstr ""
+"#3248, Empêcher la suppression des arêtes isolées si elles sont utilisées "
+"dans une TopoGeometry (Sandro Santilli)"
 #. Tag: para
 #: release_notes.xml:507
@@ -1999,6 +2014,8 @@ msgid ""
 "#3231, Prevent removing isolated nodes if used in a TopoGeometry (Sandro "
 "Santilli)"
 msgstr ""
+"#3231, Empêcher la suppression des noeuds isolés s'ils sont utilisés dans "
+"une TopoGeometry (Sandro Santilli)"
 #. Tag: para
 #: release_notes.xml:509
@@ -2015,6 +2032,8 @@ msgid ""
 "#4950, Speed up checking containing_face for nodes in ValidateTopology "
 "(Sandro Santilli)"
 msgstr ""
+"#4950, Accélérer la vérification de containing_face pour les noeuds dans "
+"ValidateTopology (Sandro Santilli)"
 #. Tag: para
 #: release_notes.xml:513
@@ -2031,9 +2050,11 @@ msgstr ""
 #. Tag: para
 #: release_notes.xml:515
-#, no-c-format
+#, fuzzy, no-c-format
 msgid "#3042, ValidateTopology check for edge linking (Sandro Santilli)"
 msgstr ""
+"#3042, Vérification de ValidateTopology pour la liaison des arêtes (Sandro "
+"Santilli)"
 #. Tag: para
 #: release_notes.xml:516
Summary of changes:
 doc/po/fr/release_notes.xml.po | 29 +++++++++++++++++++++++++----
 1 file changed, 25 insertions(+), 4 deletions(-)
hooks/post-receive
