[postgis-tickets] [PostGIS] #5397: debug_standardize_address
PostGIS trac at osgeo.org
Sun Jun 25 15:12:58 PDT 2023
  Reporter:  robe                 |      Owner:  robe
      Type:  enhancement          |     Status:  closed
  Priority:  high                 |  Milestone:  PostGIS 3.4.0
 Component:  pagc_address_parser  |    Version:  master
Resolution:  fixed                |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"d9016782e1de2344d9dde9fefccd98be49212e8d/git" d901678/git]:
 {{{#!CommitTicketReference repository="git"
 revision="d9016782e1de2344d9dde9fefccd98be49212e8d"
  - Add rule_string and rule_id, by looking up from rule table
  - If no matching rule found (shouldn't happen but it does)
    return -1 for rule_id
  - Also return rule_stub_string which is the filter used to
    search for the rule in rule table
  - Add test to output rule_string/rule_stub_string
 Closes #5397
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5397#comment:9>
