[postgis-tickets] [PostGIS] #5297: woodie and dronie not picking up docbook check issues
PostGIS trac at osgeo.org
Mon Jun 26 07:23:08 PDT 2023
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  reopened
  Priority:  critical   |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 A Woodie build from 2 days ago is still missing xmllint:
 https://woodie.osgeo.org/postgis/postgis/build/429/7
 I guess we need to add pull:true to the image config,
 see https://woodpecker-ci.org/docs/usage/pipeline-syntax
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5297#comment:7>
