[postgis-tickets] [PostGIS] #5411: French manual broken
PostGIS trac at osgeo.org
Mon Jun 26 07:51:59 PDT 2023
 Reporter:  strk     |      Owner:  robe
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.4.0
Component:  l18n     |    Version:  master
 Keywords:           |
 I'm not sure since when as Woodie has not been really testing lately, but
 the french translation is currently broken:
 postgis_aggs_mm.xml:5819: element sect2: validity error : Element sect2
 content does not follow the DTD, expecting (sect2info? , (title ,
 subtitle? , titleabbrev?) , (toc | lot | index | glossary | bibliography)*
 , (((calloutlist | glosslist | bibliolist | itemizedlist | orderedlist |
 segmentedlist | simplelist | variablelist | caution | important | note |
 tip | warning | literallayout | programlisting | programlistingco | screen
 | screenco | screenshot | synopsis | cmdsynopsis | funcsynopsis |
 classsynopsis | fieldsynopsis | constructorsynopsis | destructorsynopsis |
 methodsynopsis | formalpara | para | simpara | address | blockquote |
 graphic | graphicco | mediaobject | mediaobjectco | informalequation |
 informalexample | informalfigure | informaltable | equation | example |
 figure | table | msgset | procedure | sidebar | qandaset | task | anchor |
 bridgehead | remark | highlights | abstract | authorblurb | epigraph |
 indexterm | beginpage)+ , (refentry* | sect3* | simplesect*)) | refentry+
 | sect3+ | simplesect+) , (toc | lot | index | glossary | bibliography)*),
 got (title )
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5411>
