[postgis-tickets] [PostGIS] #5412: Manual support tags not being translated
PostGIS trac at osgeo.org
Mon Jun 26 09:45:32 PDT 2023
  Reporter:  strk    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 3.4.0
 Component:  l18n    |    Version:  master
Resolution:          |   Keywords:
Comment (by strk):
 I've given the external .xml idea a try. In order to work it requires
 wrapping the entity into a <para> which in turns forces a new paragraph
 breaking the SQL-1.1 information integration in some functions, for
 example the {{{ SQLMM-3 7.2.4 }}} specification you find in
 https://postgis.net/docs/manual-dev/ST_NumPoints.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5412#comment:2>
