[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1008-g84e7fd214
Mon Jun 26 17:41:52 PDT 2023
the project "PostGIS".
       via  84e7fd214660e3c70f02c1ed7cf9d9b200df2be1 (commit)
      from  4db6905ebed90ece2492a51a6e32beb48d6aab6a (commit)
revisions in full, below.
commit 84e7fd214660e3c70f02c1ed7cf9d9b200df2be1
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jun 26 20:31:40 2023 -0400
    ST_Value bilinear
     - Don't throw an error if nodatavalue, instead use 0
     - Add tests for bilinear
     Closes #5410 for PostGIS 3.4.0dev
diff --git a/raster/rt_core/rt_band.c b/raster/rt_core/rt_band.c
index c46ee81f4..66aa19431 100644
--- a/raster/rt_core/rt_band.c
+++ b/raster/rt_core/rt_band.c
@@ -1262,7 +1262,6 @@ rt_band_get_pixel_bilinear(
 	double xr, double yr,
 	double *r_value, int *r_nodata)
-	rt_errorstate err;
 	double xcenter, ycenter;
 	double values[2][2];
 	double nodatavalue = 0.0;
@@ -1294,9 +1293,11 @@ rt_band_get_pixel_bilinear(
 	xdir = xr < xcenter ? 1 : 0;
 	ydir = yr < ycenter ? 1 : 0;
-	err = rt_band_get_nodata(band, &nodatavalue);
-	if (err != ES_NONE) {
-		nodatavalue = 0.0;
+	if (rt_band_get_hasnodata_flag(band) != FALSE) {
+			rt_band_get_nodata(band, &nodatavalue);
+	else {
+			nodatavalue = 0.0;
 	/* Read the 2x2 values from the band */
diff --git a/raster/test/regress/rt_pixelvalue.sql b/raster/test/regress/rt_pixelvalue.sql
index fb9c05341..942c1e889 100644
--- a/raster/test/regress/rt_pixelvalue.sql
+++ b/raster/test/regress/rt_pixelvalue.sql
@@ -288,6 +288,8 @@ SELECT 'test 1.10', id
 -- Test 2 - st_value(rast raster, band integer, pt geometry)
+--        - st_value(rast raster, band integer, pt geometry,
+--                   boolean exclude_nodata_value=true, text resample)
 SELECT 'test 2.1', id
@@ -298,6 +300,18 @@ SELECT 'test 2.2', id
     FROM rt_band_properties_test
     WHERE st_value(rast, 2, st_makepoint(st_upperleftx(rast), st_upperlefty(rast))) != b2val;
+SELECT 'test 2.3', id, st_value(rast, 1,
+	ST_Centroid(rast::geometry),
+		 true, 'bilinear') AS val
+    FROM rt_band_properties_test
+    WHERE id = 1;
+SELECT '#5410', id, st_value(
+		ST_SetBandNoDataValue(rast,1,NULL), 1,
+		 true, 'bilinear') As val
+	WHERE id = 1;
 -- Test 3 - st_pixelaspolygon(rast raster, x integer, y integer)
diff --git a/raster/test/regress/rt_pixelvalue_expected b/raster/test/regress/rt_pixelvalue_expected
index 49194c799..7576caaff 100644
--- a/raster/test/regress/rt_pixelvalue_expected
+++ b/raster/test/regress/rt_pixelvalue_expected
@@ -4,6 +4,8 @@ NOTICE:  Attempting to get pixel value with out of range raster coordinates: (-2
 NOTICE:  Attempting to get pixel value with out of range raster coordinates: (-2, -2)
 ERROR:  Raster and geometry do not have the same SRID
+test 2.3|1|2
+#5410|1|2
 NOTICE:  Raster do not have a nodata value defined. Set band nodata value first. Nodata value not set. Returning original raster
Summary of changes:
 raster/rt_core/rt_band.c                   |  9 +++++----
 raster/test/regress/rt_pixelvalue.sql      | 14 ++++++++++++++
 raster/test/regress/rt_pixelvalue_expected |  2 ++
 3 files changed, 21 insertions(+), 4 deletions(-)
hooks/post-receive
