[postgis-tickets] [PostGIS] #5413: PDF manual cannot be built with out-of-tree builds
PostGIS trac at osgeo.org
Tue Jun 27 06:56:50 PDT 2023
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:
 Keywords:                         |
 Wrong path for the custom style:
 if test x"/usr/bin/dblatex" = x; then \
    echo "Error: dblatex not found, can't build pdf"; \
    echo "       try installing dblatex and then re-run configure"; \
    false; \
 else \
         /usr/bin/dblatex -T native -t pdf \
            -I "/usr/local/src/postgis/postgis/build/pg13/doc/html" \
            -P doc.collab.show=0 \
            -P
 figure.note="/usr/local/src/postgis/postgis/build/pg13/doc/html/images/note"
            -P
 figure.tip="/usr/local/src/postgis/postgis/build/pg13/doc/html/images/tip"
            -P
 figure.important="/usr/local/src/postgis/postgis/build/pg13/doc/html/images/important"
            -P
 figure.warning="/usr/local/src/postgis/postgis/build/pg13/doc/html/images/warning"
            -P
 figure.caution="/usr/local/src/postgis/postgis/build/pg13/doc/html/images/caution"
            -P latex.output.revhistory=0 \
            -s "/usr/local/src/postgis/postgis/build/pg13/doc/texstyle.sty"
            -o postgis-3.4.0dev-ru.pdf postgis-out.xml; \
 fi
 Error: Latex style
 '/usr/local/src/postgis/postgis/build/pg13/doc/texstyle.sty' not found
 Evidently none of our bots are building the PDFs, this is something to fix
 too
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5413>
