[postgis-tickets] [PostGIS] #5278: GHA PG16 tests failing on all warnings being treated as errors
PostGIS trac at osgeo.org
Tue Jun 27 09:45:55 PDT 2023
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"9401093fc80073ae294d312a99be7338ceac7f66/git" 9401093/git]:
 {{{#!CommitTicketReference repository="git"
 revision="9401093fc80073ae294d312a99be7338ceac7f66"
 FIX GHA 16 latest warnings
 Closes #5278 for PostGIS 3.4.0
  - Turn back on warnings notices on latest (switch back tests mode)
  - Fix shadow warnings on gserialized gist c files
  - Fix shawow warning on mvt
  - Fix double-free warning on address_standardizer
  - Fix strncopy length depends on bounds of source instead of dest
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5278#comment:6>
