[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1017-g1985836e4
Tue Jun 27 12:23:24 PDT 2023
the project "PostGIS".
       via  1985836e47d4566a978d0b298ae2a86b89b6b283 (commit)
      from  3874270a400eb1295f7512edad88e7fa22aad816 (commit)
revisions in full, below.
commit 1985836e47d4566a978d0b298ae2a86b89b6b283
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jun 27 12:23:21 2023 -0700
    Change local var names to avoid shadows, references #5278
diff --git a/extensions/address_standardizer/gamma.c b/extensions/address_standardizer/gamma.c
index 413d957a9..0824c6535 100644
--- a/extensions/address_standardizer/gamma.c
+++ b/extensions/address_standardizer/gamma.c
@@ -163,7 +163,7 @@ RULES *rules_init( ERR_PARAM *err_p ) {
        rules_free(rules);
-       return NULL ;
+       return NULL;
     rules -> r_p -> rule_space = r_s ;
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index a7a290c87..c50be7591 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -844,7 +844,6 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 	SHPObject *obj = NULL;
 	int ret = SHPLOADEROK;
 	char name[MAXFIELDNAMELEN];
-	char name2[MAXFIELDNAMELEN];
 	DBFFieldType type = FTInvalid;
 	char *utf8str;
@@ -1164,24 +1163,26 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 		 * or after pgsql reserved attribute names
 		if (name[0] == '_' ||
-		        ! strcmp(name, "gid") || ! strcmp(name, "tableoid") ||
+		        ! strcmp(name, "gid") ||
+		        ! strcmp(name, "tableoid") ||
 		        ! strcmp(name, "cmin") ||
 		        ! strcmp(name, "cmax") ||
 		        ! strcmp(name, "xmin") ||
 		        ! strcmp(name, "xmax") ||
 		        ! strcmp(name, "primary") ||
-		        ! strcmp(name, "oid") || ! strcmp(name, "ctid"))
+		        ! strcmp(name, "oid") ||
+		        ! strcmp(name, "ctid"))
+			char tmp_name[MAXFIELDNAMELEN];
 			size_t len = strlen(name);
-			if (len > (MAXFIELDNAMELEN - 2)){
+			if (len > (MAXFIELDNAMELEN - 2))
 				len = MAXFIELDNAMELEN - 2;
-			strncpy(name2 + 2, name, MAXFIELDNAMELEN - 2);
-			name2[MAXFIELDNAMELEN-1] = '\0';
-			name2[len + 2] = '\0';
-			name2[0] = '_';
-			name2[1] = '_';
-			strcpy(name, name2);
+			strncpy(tmp_name + 2, name, len);
+			tmp_name[len+1] = '\0';
+			tmp_name[0] = tmp_name[1] = '_';
+			strcpy(name, tmp_name);
 		/* Avoid duplicating field names */
diff --git a/postgis/gserialized_spgist_3d.c b/postgis/gserialized_spgist_3d.c
index 60371b6e0..8ee0cb38b 100644
--- a/postgis/gserialized_spgist_3d.c
+++ b/postgis/gserialized_spgist_3d.c
@@ -424,7 +424,6 @@ PGDLLEXPORT Datum gserialized_spgist_picksplit_3d(PG_FUNCTION_ARGS)
 	spgPickSplitOut *out = (spgPickSplitOut *)PG_GETARG_POINTER(1);
 	BOX3D *centroid;
 	int median, i;
-	uint8 octant;
 	double *lowXs = palloc(sizeof(double) * in->nTuples);
 	double *highXs = palloc(sizeof(double) * in->nTuples);
 	double *lowYs = palloc(sizeof(double) * in->nTuples);
@@ -437,14 +436,14 @@ PGDLLEXPORT Datum gserialized_spgist_picksplit_3d(PG_FUNCTION_ARGS)
 	/* Calculate median of all 6D coordinates */
 	for (i = 0; i < in->nTuples; i++)
-		box = DatumGetBox3DP(in->datums[i]);
-		lowXs[i] = box->xmin;
-		highXs[i] = box->xmax;
-		lowYs[i] = box->ymin;
-		highYs[i] = box->ymax;
-		lowZs[i] = box->zmin;
-		highZs[i] = box->zmax;
+		BOX3D* box_in = DatumGetBox3DP(in->datums[i]);
+		lowXs[i] = box_in->xmin;
+		highXs[i] = box_in->xmax;
+		lowYs[i] = box_in->ymin;
+		highYs[i] = box_in->ymax;
+		lowZs[i] = box_in->zmin;
+		highZs[i] = box_in->zmax;
 	qsort(lowXs, in->nTuples, sizeof(double), compareDoubles);
@@ -482,10 +481,10 @@ PGDLLEXPORT Datum gserialized_spgist_picksplit_3d(PG_FUNCTION_ARGS)
-		octant = getOctant(centroid, box);
+		uint8 octant = getOctant(centroid, box_in);
-		out->leafTupleDatums[i] = Box3DPGetDatum(box);
+		out->leafTupleDatums[i] = Box3DPGetDatum(box_in);
 		out->mapTuplesToNodes[i] = octant;
diff --git a/postgis/mvt.c b/postgis/mvt.c
index d35514952..8aa916052 100644
--- a/postgis/mvt.c
+++ b/postgis/mvt.c
@@ -1109,9 +1109,9 @@ static bytea *mvt_ctx_to_bytea(mvt_agg_context *ctx)
 	/* Zero features => empty bytea output */
 	if (ctx && ctx->layer && ctx->layer->n_features == 0)
-		ba = palloc(VARHDRSZ);
-		SET_VARSIZE(ba, VARHDRSZ);
-		return ba;
+		bytea* ba_empty = palloc(VARHDRSZ);
+		SET_VARSIZE(ba_empty, VARHDRSZ);
+		return ba_empty;
 	/* Serialize the Tile */
Summary of changes:
 extensions/address_standardizer/gamma.c |  2 +-
 loader/shp2pgsql-core.c                 | 21 +++++++++++----------
 postgis/gserialized_spgist_3d.c         | 23 +++++++++++------------
 postgis/mvt.c                           |  6 +++---
 4 files changed, 26 insertions(+), 26 deletions(-)
hooks/post-receive
