[postgis-tickets] [PostGIS] #5415: dump restore failure function "st_largestemptycircle" already exists with same argument types
PostGIS trac at osgeo.org
Wed Jun 28 16:21:00 PDT 2023
same argument types
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  3.3.x
 Keywords:                         |
 Seeing this error on gitlab dump/restore with new function
 Died at /builds/postgis/postgis/regress/run_test.pl line 426.
  failed (Could not restore postgis_reg-3.4: /tmp/pgis_reg/regress_log)
 NOTICE:  schema "public" already exists, skipping
 psql:/tmp/build/regress/00-regress-
 install/share/contrib/postgis/topology.sql:388: NOTICE:  constraint
 "type_range" of domain "topology.topoelement" does not exist, skipping
 install/share/contrib/postgis/topology.sql:686: NOTICE:  function
 topology.populate_topology_layer() does not exist, skipping
 install/share/contrib/postgis/topology.sql:2938: NOTICE:  aggregate
 topology.topoelementarray_agg(topology.topoelement) does not exist,
 skipping
                      addtosearchpath
  topology has been added to end of database search_path
 (1 row)
 SET
 ALTER TABLE
 ALTER TABLE
 ALTER TABLE
 SELECT 8500
 DELETE 8500
 SET
 SET
 SET
 SET
 SET
  set_config
 (1 row)
 SET
 SET
 SET
 SET
 ERROR:  function "st_largestemptycircle" already exists with same argument
 types
 make: *** [/builds/postgis/postgis/regress/runtest.mk:24: check-regress]
 Error 3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5415>
