[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1067-gdc5503e59
Thu Jun 29 04:43:04 PDT 2023
the project "PostGIS".
       via  dc5503e59a8bfdb37ce80fae3a958fb2d0d474de (commit)
      from  a95900d1d576b8bf2568cda12c415f04398f4f42 (commit)
revisions in full, below.
commit dc5503e59a8bfdb37ce80fae3a958fb2d0d474de
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jun 29 12:10:27 2023 +0200
    Fix skip signature of function with out and inout parameters
    Fixes restore of PostGIS dumps from 3.4.0 (ST_LargestEmptyCircle).
    Removes needlessly hardcoded signatures in postgis_restore.pl.in.
    Adds postgis_restore.pl code duplication check and clean targets.
    Closes #5415
diff --git a/.gitignore b/.gitignore
index 577e36542..17f90ed10 100644
--- a/.gitignore
+++ b/.gitignore
@@ -189,8 +189,7 @@ libpgcommon/Makefile
 libpgcommon/cunit/Makefile
 utils/Makefile
 utils/postgis_restore.pl
-utils/postgis_restore_data.generated
-utils/postgis_restore_data.hardcoded
+utils/postgis_restore_data.*
 doc/sfcgal_comments.sql
 postgis/sfcgal.sql
 postgis/uninstall_sfcgal.sql
diff --git a/utils/Makefile.in b/utils/Makefile.in
index 774724402..4e72d51b4 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -88,14 +88,33 @@ postgis_restore.pl: postgis_restore.pl.in postgis_restore_data.hardcoded postgis
 		| sort -u >> postgis_restore.pl
 	chmod +x $@
+postgis_restore_data.needlessly-hardcoded: postgis_restore_data.hardcoded postgis_restore_data.generated
+	comm -12 postgis_restore_data.hardcoded postgis_restore_data.generated > $@
+postgis_restore-check: postgis_restore_data.needlessly-hardcoded
+	@if test -s $<; then { \
+		echo "Needlessly hardcoded signatures found postgis_restore.pl.in:"; \
+		sed 's/^/  /' $<; \
+		echo "Use 'make postgis_restore-clean' to fix that"; \
+	} >&2 && false; fi
+postgis_restore-clean: postgis_restore_data.needlessly-hardcoded
+	mv $(srcdir)/postgis_restore.pl.in $(srcdir)/postgis_restore.pl.in~
+	grep -Fxvf $< $(srcdir)/postgis_restore.pl.in~ > $(srcdir)/postgis_restore.pl.in
 clean:
-	rm -f $(SCRIPTS_built) postgis_restore_data.generated postgis_restore_data.hardcoded
+	rm -f $(SCRIPTS_built) postgis_restore_data.*
 distclean: clean
 	rm -f Makefile
-# And there's nothing to check
-check check-unit check-regress:
+# There's nothing to check for regress
+check-regress:
+check: check-unit
+check-unit: postgis_restore-check
 installdir:
 	@mkdir -p $(DESTDIR)$(bindir)
diff --git a/utils/create_skip_signatures.pl b/utils/create_skip_signatures.pl
index 576a85c1b..81696964e 100644
--- a/utils/create_skip_signatures.pl
+++ b/utils/create_skip_signatures.pl
@@ -34,6 +34,35 @@ my %reserved_sql_word = (
 	'character' => 1
+# Example:
+#  INPUT: inout first double precision, second integer, OUT third text, fourth bool
+# OUTPUT: first double precision, second integer, fourth bool
+sub clean_inout_arguments {
+	my @args = @_;
+	my @out;
+	#print "XXX to strip: " . join(',', @args) . "\n";
+	foreach ( @args )
+		my $a = $_;
+		#print "  XXX arg: [$a]\n";
+		# If the arg is composed by multiple words
+		# check for out and inout indicators
+		if ( $a =~ m/([^ ]*) (.*)/ )
+			# Skip this arg if out only
+			next if $1 eq 'out';
+			# Hide the inout indicator
+			$a = $2 if $1 eq 'inout';
+		#print "  XXX arg became: $a\n";
+		push @out, $a;
+	#print "XXX striped: " . join(',', @out) . "\n";
+	return @out;
 # Example:
 #  INPUT: int,named double precision,named text
 # OUTPUT: int,double precision,text
@@ -143,9 +172,17 @@ while (<>)
 		print "COMMENT FUNCTION $name(" . join(', ', @args) .")\n";
-		# For *function* signature we are supposed to strip
-		# also argument names, which aint easy
-		my @unnamed_args = strip_argument_names(@args);
+		# Example manifest line for comments on function with inout params:
+		# 4247; 0 0 COMMENT public FUNCTION testinoutmix(INOUT "inout" double precision, second integer, OUT thirdout integer, fourth integer) strk
+		# Example manifest line for function with inout params:
+		# 955; 1255 27730785 FUNCTION public testinoutmix(double precision, integer, integer) strk
+		# No inout indicator or out parameters for function signatures
+		my @inonly_args = clean_inout_arguments(@args);
+		# For *function* signature we are supposed to strip argument names
+		my @unnamed_args = strip_argument_names(@inonly_args);
 		print "FUNCTION $name(" . join(', ', @unnamed_args) . ")\n";
diff --git a/utils/postgis_restore.pl.in b/utils/postgis_restore.pl.in
index cef63213e..c6e23ba48 100644
--- a/utils/postgis_restore.pl.in
+++ b/utils/postgis_restore.pl.in
@@ -642,10 +642,7 @@ FUNCTION jsonb(geometry)
 FUNCTION json(geometry)
 FUNCTION lockrow(text, text, text, text, timestamp without time zone)
 FUNCTION lockrow(text, text, text, timestamp without time zone)
-FUNCTION _overview_constraint_info(name, name, name)
 FUNCTION postgis_extensions_upgrade()
-FUNCTION st_asgeojson(record, text, integer, boolean)
-FUNCTION st_asmvtgeom(geometry, box2d, integer, integer, boolean)
 FUNCTION _st_aspect4ma(double precision[], integer[], text[])
 FUNCTION st_clusterkmeans(geometry, integer)
 FUNCTION st_concavehull(geometry, double precision, boolean)
@@ -657,9 +654,7 @@ FUNCTION st_force3d(geometry)
 FUNCTION st_force3dm(geometry)
 FUNCTION st_force3dz(geometry)
 FUNCTION st_force4d(geometry)
-FUNCTION st_geotransform(raster)
 FUNCTION _st_grayscale4ma(double precision[], integer[], text[])
-FUNCTION st_hexagongrid(double precision, geometry)
 FUNCTION _st_hillshade4ma(double precision[], integer[], text[])
 FUNCTION st_intersection(geometry, geometry)
 FUNCTION st_invdistweight4ma(double precision[], integer[], text[])
@@ -671,17 +666,13 @@ FUNCTION st_mapalgebra(raster, integer, regprocedure, text, text, raster, intege
 FUNCTION st_mapalgebra(raster, integer[], regprocedure, text, text, raster, integer, integer, text[])
 FUNCTION st_max4ma(double precision[], integer[], text[])
 FUNCTION st_max4ma(double precision[], text, text[])
-FUNCTION st_maximuminscribedcircle(geometry)
 FUNCTION st_mean4ma(double precision[], integer[], text[])
 FUNCTION st_mean4ma(double precision[], text, text[])
-FUNCTION st_metadata(raster)
 FUNCTION st_min4ma(double precision[], integer[], text[])
 FUNCTION st_min4ma(double precision[], text, text[])
 FUNCTION st_mindist4ma(double precision[], integer[], text[])
-FUNCTION st_minimumboundingradius(geometry)
 FUNCTION st_range4ma(double precision[], integer[], text[])
 FUNCTION st_range4ma(double precision[], text, text[])
-FUNCTION _st_rastertoworldcoord(raster, integer, integer)
 FUNCTION st_rastertoworldcoord(raster, integer, integer)
 FUNCTION _st_reclass(raster, reclassarg[])
 FUNCTION st_reclass(raster, reclassarg[])
@@ -690,7 +681,6 @@ FUNCTION st_setvalues(raster, integer, integer, integer, double precision[], boo
 FUNCTION _st_setvalues(raster, integer, integer, integer, double precision[], boolean[], boolean, double precision, boolean)
 FUNCTION st_setvalues(raster, integer, integer, integer, double precision[], double precision, boolean)
 FUNCTION _st_slope4ma(double precision[], integer[], text[])
-FUNCTION st_squaregrid(double precision, geometry)
 FUNCTION st_stddev4ma(double precision[], integer[], text[])
 FUNCTION st_stddev4ma(double precision[], text, text[])
 FUNCTION st_subdivide(geometry, integer)
@@ -701,15 +691,6 @@ FUNCTION st_tileenvelope(integer, integer, integer, geometry)
 FUNCTION _st_tpi4ma(double precision[], integer[], text[])
 FUNCTION _st_tri4ma(double precision[], integer[], text[])
 FUNCTION st_unaryunion(geometry)
-FUNCTION st_valuepercent(raster, double precision[], double precision)
-FUNCTION st_valuepercent(raster, integer, boolean, double precision[], double precision)
-FUNCTION st_valuepercent(raster, integer, double precision[], double precision)
-FUNCTION st_valuepercent(text, text, double precision[], double precision)
-FUNCTION st_valuepercent(text, text, integer, boolean, double precision[], double precision)
-FUNCTION st_valuepercent(text, text, integer, double precision[], double precision)
-FUNCTION _st_worldtorastercoord(raster, double precision, double precision)
-FUNCTION st_worldtorastercoord(raster, double precision, double precision)
-FUNCTION st_worldtorastercoord(raster, geometry)
 OPERATOR &&
 OPERATOR &&&
 OPERATOR &/&
Summary of changes:
 .gitignore                      |  3 +--
 utils/Makefile.in               | 25 +++++++++++++++++++++---
 utils/create_skip_signatures.pl | 43 ++++++++++++++++++++++++++++++++++++++---
 utils/postgis_restore.pl.in     | 19 ------------------
 4 files changed, 63 insertions(+), 27 deletions(-)
hooks/post-receive
