[postgis-tickets] [PostGIS] #5416: my local install is broken xsl issues
PostGIS trac at osgeo.org
Thu Jun 29 04:46:03 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Comment (by strk):
 I've pushed a xsl-path branch to test a different approach, if you still
 have the old libxml around it would be good to test that
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5416#comment:3>
