[postgis-tickets] [PostGIS] #5055: XSL headers not being translated
PostGIS trac at osgeo.org
Thu Jun 29 08:14:47 PDT 2023
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  closed
  Priority:  medium  |  Milestone:  PostGIS 3.5.0
 Component:  l18n    |    Version:  master
Resolution:  fixed   |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"42f417e1fef8387e428741042982a852fc1a9363/git"
 42f417e1/git]:
 {{{#!CommitTicketReference repository="git"
 revision="42f417e1fef8387e428741042982a852fc1a9363"
 Make text in list of new functions translatable
 Introduces a translatable xsl-config.xml file
 that can be read by xsl scripts and uses it
 from list_new_functions.xml.xsl
 Add pot and po files for xsl-config.xml
 Closes #5055
 References #5414 as makes it possible to fix the new function
 listing by being consistent in tags translation
 Translates availability tags to French to show how the above
 works.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5055#comment:14>
