[postgis-tickets] [PostGIS] #5417: manual-dev publishes from non-master branches
PostGIS trac at osgeo.org
Thu Jun 29 08:21:13 PDT 2023
  Reporter:  strk       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:
Resolution:             |   Keywords:
Comment (by robe):
 The build is controlled by
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Make_Dist
 There are two ways to handle this.
 1.  I can put a filter on the job to ignore non-stable / master branches
 or
 2. we can change ci/debbie/postgis_make_dist.sh  check the branch it's
 building and put the build in some other folder we can check.
 That would satisfy your need to see and also not mess up what is linked on
 the website.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5417#comment:1>
