[postgis-tickets] [PostGIS] #5414: List of new/enhanced function fails due to translation
PostGIS trac at osgeo.org
Thu Jun 29 10:01:00 PDT 2023
  Reporter:  strk    |      Owner:  strk
      Type:  defect  |     Status:  closed
  Priority:  medium  |  Milestone:  PostGIS 3.4.0
 Component:  l18n    |    Version:  master
Resolution:  fixed   |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"b4005653b7d7582af52e494199a7d22642b2121d/git"
 b4005653/git]:
 {{{#!CommitTicketReference repository="git"
 revision="b4005653b7d7582af52e494199a7d22642b2121d"
 Use xml attributes to encode availablity/enhanced/changed info
 We use role and conformance common docbook attributes to not
 break the parsers.
 Use metadata to extract availability info
 Closes #5414
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5414#comment:7>
