[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1072-g6199ccb98
Thu Jun 29 10:01:09 PDT 2023
the project "PostGIS".
       via  6199ccb98f1dc07fffaafb2d3692c2805a6fa3c4 (commit)
      from  b4005653b7d7582af52e494199a7d22642b2121d (commit)
revisions in full, below.
commit 6199ccb98f1dc07fffaafb2d3692c2805a6fa3c4
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jun 29 15:31:32 2023 +0000
    Translated postgis_special using Weblate (Italian)
    Currently translated at 5.4% (3 of 55 strings)
    Translation: postgis/postgis_special
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis_special/it/
diff --git a/doc/po/it_IT/postgis_special.xml.po b/doc/po/it_IT/postgis_special.xml.po
index eebc175ef..d9970607d 100644
--- a/doc/po/it_IT/postgis_special.xml.po
+++ b/doc/po/it_IT/postgis_special.xml.po
@@ -1,19 +1,22 @@
 # Italian translations for pg package.
 # Automatically generated, 2023.
+# Sandro Santilli <strk at kbt.io>, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: pg 13\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-06-28 10:30+0000\n"
-"PO-Revision-Date: 2023-06-28 10:30+0000\n"
-"Last-Translator: Automatically generated\n"
-"Language-Team: none\n"
+"PO-Revision-Date: 2023-06-29 17:00+0000\n"
+"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
+"postgis_special/it/>\n"
+"Language: it_IT\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Language: it\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: title
 #: postgis_special.xml:3
@@ -25,7 +28,7 @@ msgstr "Indice delle funzioni speciali di PostGIS"
 #: postgis_special.xml:6
 #, no-c-format
 msgid "PostGIS Aggregate Functions"
-msgstr ""
+msgstr "Funzioni Aggregate PostGIS"
 #. Tag: para
 #: postgis_special.xml:7
@@ -35,6 +38,9 @@ msgid ""
 "same way as SQL aggregate function such as <code>sum</code> and "
 "<code>average</code>."
 msgstr ""
+"Le seguenti funzioni sono funzioni aggregate spaziali utilizzabili allo "
+"stesso modo in cui si usano le funzioni aggregate SQL quali <code>sum</code> "
+"e <code>average</code>."
 #. Tag: sect1
Summary of changes:
 doc/po/it_IT/postgis_special.xml.po | 18 ++++++++++++------
 1 file changed, 12 insertions(+), 6 deletions(-)
hooks/post-receive
