[postgis-tickets] [PostGIS] #5416: my local install is broken xsl issues
PostGIS trac at osgeo.org
Thu Jun 29 10:42:29 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Nope, still not good:
         /usr/bin/dblatex -T native -t pdf \
            -x "--path
 .:./ent:/home/src/postgis/postgis/doc:/home/src/postgis/postgis/doc/ent" \
            -I "/usr/local/src/postgis/postgis/b/doc/html" \
            -P doc.collab.show=0 \
            -P
 figure.note="/usr/local/src/postgis/postgis/b/doc/html/images/note" \
            -P
 figure.tip="/usr/local/src/postgis/postgis/b/doc/html/images/tip" \
            -P
 figure.important="/usr/local/src/postgis/postgis/b/doc/html/images/important"
            -P
 figure.warning="/usr/local/src/postgis/postgis/b/doc/html/images/warning"
            -P
 figure.caution="/usr/local/src/postgis/postgis/b/doc/html/images/caution"
            -P latex.output.revhistory=0 \
            -s "/home/src/postgis/postgis/doc/texstyle.sty" \
            -o postgis-3.4.0dev.pdf postgis-out.xml
 Build the book set list...
 warning: failed to load external entity
 "/home/src/postgis/postgis/doc/ent/list_aggregates.xsl.xml"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5416#comment:7>
