[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1075-gd9f1ec0a4
Thu Jun 29 12:19:59 PDT 2023
the project "PostGIS".
       via  d9f1ec0a473c8443fe911e2a3f8bfac574e75be3 (commit)
      from  2e6f30da278829430e15ae040bf7ac6d175fb5f8 (commit)
revisions in full, below.
commit d9f1ec0a473c8443fe911e2a3f8bfac574e75be3
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jun 29 21:15:12 2023 +0200
    Use absolute paths for XSLT, stop using subdir for entity file
    Fixes #5416
    Fixes #5413
diff --git a/.gitignore b/.gitignore
index 17f90ed10..b2c83d0ff 100644
--- a/.gitignore
+++ b/.gitignore
@@ -36,7 +36,6 @@ doc/po/*/*.xml
 doc/po/*/html
 doc/po/*/Makefile
 doc/po/*/xsl
-doc/po/*/ent
 doc/po/*/*_comments.sql
 doc/postgis_comments.sql
 doc/postgis-out.xml
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 8034bc60b..e3294670a 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -31,6 +31,7 @@ builddir = @builddir@
 top_builddir = @top_builddir@
 mandir = @mandir@
 abs_srcdir = @abs_srcdir@
+abs_builddir = @abs_builddir@
 POSTGIS_MAJOR_VERSION=@POSTGIS_MAJOR_VERSION@
 POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
@@ -61,7 +62,7 @@ ifeq ($(XSLTPROCFLAGS),)
 endif
 XSLT_PATH= \
-	.:./ent:$(abs_srcdir):$(abs_srcdir)/ent
+	$(abs_builddir):$(abs_srcdir)
 XSLTPROC_PATH_OPT= \
 	--path $(XSLT_PATH)
diff --git a/doc/po/Makefile.local b/doc/po/Makefile.local
index 7c1a272a0..8ca8f1fc5 100644
--- a/doc/po/Makefile.local
+++ b/doc/po/Makefile.local
@@ -18,7 +18,6 @@ local-check: symlinks
 symlinks:
 	rm -f html; ln -s ../../html html
 	rm -f xsl; ln -s $(srcdir)/../../xsl xsl
-	rm -f ent; ln -s $(srcdir)/../../ent ent
 # for XML_SOURCES
 include ../../Makefile
diff --git a/doc/ent/postgis_special.ent b/doc/postgis_special.ent
similarity index 100%
rename from doc/ent/postgis_special.ent
rename to doc/postgis_special.ent
Summary of changes:
 .gitignore                        | 1 -
 doc/Makefile.in                   | 3 ++-
 doc/po/Makefile.local             | 1 -
 doc/{ent => }/postgis_special.ent | 0
 4 files changed, 2 insertions(+), 3 deletions(-)
 rename doc/{ent => }/postgis_special.ent (100%)
hooks/post-receive
