[postgis-tickets] [PostGIS] #5418: Don't know what gentext to create for xref to: "listitem" (linkend=tiger_geocoder_loading_data)
PostGIS trac at osgeo.org
Thu Jun 29 13:44:44 PDT 2023
  Reporter:  strk           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.4.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by strk):
 The HTML version uses a made up number as the generated text. Maybe the
 PDF output is unable to do that.
 {{{ Refer to 4 for instructions on how to run the generate script. This
 only needs to be done once. }}}
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5418#comment:1>
