[postgis-tickets] [PostGIS] #5413: PDF manual cannot be built with out-of-tree builds
PostGIS trac at osgeo.org
Fri Jun 30 01:34:57 PDT 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"b467355d7f7f2305570e7b347cd7eb44ff06d59b/git"
 b467355d/git]:
 {{{#!CommitTicketReference repository="git"
 revision="b467355d7f7f2305570e7b347cd7eb44ff06d59b"
 Fix out-of-tree PDF build by adding srcdir to images path
 Closes #5413
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5413#comment:5>
