[postgis-tickets] [PostGIS] #5422: EPUB Makefile target requires manually copying files around
PostGIS trac at osgeo.org
Fri Jun 30 07:43:51 PDT 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"9245672620f42ee45ce83526a5234771219c073e/git" 9245672/git]:
 {{{#!CommitTicketReference repository="git"
 revision="9245672620f42ee45ce83526a5234771219c073e"
 Fix EPUB build (only in-tree builds)
 Moves all postgis_special entities to top-level file,
 symlink html images dir to make dbtoepub happy.
 Simplify debbie epub generation code
 Closes #5422
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5422#comment:5>
