[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1091-gaeb6f6aa6
Fri Jun 30 15:07:55 PDT 2023
the project "PostGIS".
       via  aeb6f6aa634542af74b3cc9b9792d77ad7798aab (commit)
      from  494e4f7c64558fee8335662144cc95ce4debe234 (commit)
revisions in full, below.
commit aeb6f6aa634542af74b3cc9b9792d77ad7798aab
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Jun 30 15:06:25 2023 -0700
    Add extra signatures for ST_Project,
    * ST_Project(geom, distance, azimuth)
    * ST_Project(geom, geom, distance)
    * ST_Project(geog, geog, distance)
    In partial fulfillment of #5267, but still
    probably need an explicit line extender.
diff --git a/NEWS b/NEWS
index 1ae3f983d..14228e179 100644
--- a/NEWS
+++ b/NEWS
@@ -23,6 +23,7 @@ PostGIS 3.4.0dev
   - GH721, New window-based ST_ClusterWithinWin and ST_ClusterIntersectingWin (Paul Ramsey)
   - #5397, [address_standardizer] debug_standardize_address function (Regina Obe)
   - ST_LargestEmptyCircle, exposes extra semantics on circle finding (Martin Davis)
+  - ST_Project signature for geometry, and two-point signature (Paul Ramsey)
 * Enhancements *
   - #5194, do not update system catalogs from postgis_extensions_upgrade (Sandro Santilli)
@@ -35,6 +36,7 @@ PostGIS 3.4.0dev
   - Repair spatial planner stats to use computed selectivity for contains/within queries (Paul Ramsey)
   - GH734, Additional metadata on Proj installation in postgis_proj_version (Paul Ramsey)
   - #5177, allow building tools without PostgreSQL server headers (Sandro Santilli)
 * Bug Fix *
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index a9091ece9..1e94574c4 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -1879,36 +1879,67 @@ FROM ST_GeogFromText('MULTIPOLYGON(((-71.1044543107478 42.340674480411,-71.10445
 		  <refsynopsisdiv>
 			<funcsynopsis>
 			  <funcprototype>
-				<funcdef>geography <function>ST_Project</function></funcdef>
-				<paramdef><type>geography </type>
+				<funcdef>geometry <function>ST_Project</function></funcdef>
+				<paramdef><type>geometry </type>
 				<parameter>g1</parameter></paramdef>
 				<paramdef><type>float </type>
 				<parameter>distance</parameter></paramdef>
 				<parameter>azimuth</parameter></paramdef>
 			  </funcprototype>
+              <funcprototype>
+                <parameter>g1</parameter></paramdef>
+                <parameter>g2</parameter></paramdef>
+                <paramdef><type>float </type>
+                <parameter>distance</parameter></paramdef>
+              </funcprototype>
+              <funcprototype>
+                <funcdef>geography <function>ST_Project</function></funcdef>
+                <paramdef><type>geography </type>
+                <parameter>azimuth</parameter></paramdef>
+              </funcprototype>
+              <funcprototype>
+              </funcprototype>
 			</funcsynopsis>
 		  </refsynopsisdiv>
 		  <refsection>
 			<title>Description</title>
-			<para>Returns a point projected from a start point along a geodesic using
-			a given distance and azimuth (bearing).
-			This is known as the direct geodesic problem.</para>
+			<para>Returns a point projected from a point along a geodesic using a given distance and azimuth (bearing). This is known as the direct geodesic problem.</para>
+            <para>The two-point version uses the path from the first to the second point to implicitly define the azimuth and uses the distance as before.</para>
 			<para>The distance is given in meters.  Negative values are supported.</para>
 			<para>The azimuth (also known as heading or bearing) is given in radians.
-			It is measured clockwise from true north (azimuth zero).
-			East is azimuth &#x03C0;/2 (90 degrees);
-			south is azimuth &#x03C0; (180 degrees);
-			west is azimuth 3&#x03C0;/2 (270 degrees).
-			Negative azimuth values and values greater than 2&#x03C0; (360 degrees) are supported.
-			</para>
+			It is measured clockwise from true north.</para>
+            <itemizedlist>
+                <listitem><para>North is azimuth zero (0 degrees)</para></listitem>
+                <listitem><para>East is azimuth &#x03C0;/2 (90 degrees)</para></listitem>
+                <listitem><para>South is azimuth &#x03C0; (180 degrees)</para></listitem>
+                <listitem><para>West is azimuth 3&#x03C0;/2 (270 degrees)</para></listitem>
+            </itemizedlist>
+            <para>Negative azimuth values and values greater than 2&#x03C0; (360 degrees) are supported.</para>
 			<para role="availability" conformance="2.0.0">Availability: 2.0.0</para>
 			<para role="enhanced" conformance="2.4.0">Enhanced: 2.4.0 Allow negative distance and non-normalized azimuth.</para>
+            <para role="enhanced" conformance="3.4.0">Enhanced: 3.4.0 Allow geometry arguments and two-point form omitting azimuth.</para>
 		  </refsection>
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index f79303a57..3bf5b4820 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1339,6 +1339,8 @@ extern LWPOINT* lwcompound_get_lwpoint(const LWCOMPOUND *lwcmp, uint32_t where);
 extern double ptarray_length_2d(const POINTARRAY *pts);
 extern int pt_in_ring_2d(const POINT2D *p, const POINTARRAY *ring);
 extern int azimuth_pt_pt(const POINT2D *p1, const POINT2D *p2, double *ret);
+extern LWPOINT* lwpoint_project_lwpoint(const LWPOINT* lwpoint1, const LWPOINT* lwpoint2, double distance);
+extern LWPOINT* lwpoint_project(const LWPOINT* lwpoint1, double distance, double azimuth);
 extern int lwpoint_inside_circle(const LWPOINT *p, double cx, double cy, double rad);
 extern LWGEOM* lwgeom_reverse(const LWGEOM *lwgeom);
@@ -1744,6 +1746,11 @@ extern double lwgeom_distance_spheroid(const LWGEOM *lwgeom1, const LWGEOM *lwge
 extern LWPOINT* lwgeom_project_spheroid(const LWPOINT *r, const SPHEROID *spheroid, double distance, double azimuth);
+* Calculate the location of a point on a spheroid, give a start point, end point and distance.
+extern LWPOINT* lwgeom_project_spheroid_lwpoint(const LWPOINT *from, const LWPOINT *to, const SPHEROID *spheroid, double distance);
 * Derive a new geometry with vertices added to ensure no vertex is more
 * than max_seg_length (in radians) from any other vertex.
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index 4fa50ddc3..cc45fdeef 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -253,6 +253,12 @@ int p4d_same(const POINT4D *p1, const POINT4D *p2);
 int p3d_same(const POINT3D *p1, const POINT3D *p2);
 int p2d_same(const POINT2D *p1, const POINT2D *p2);
+* Projections
+int project_pt(const POINT2D *P, double distance, double azimuth, POINT2D *R);
+int project_pt_pt(const POINT4D *A, const POINT4D *B, double distance, POINT4D *R);
 * Area calculations
@@ -356,7 +362,9 @@ int ptarray_isccw(const POINTARRAY *pa);
 * Same
+char ptarray_same2d(const POINTARRAY *pa1, const POINTARRAY *pa2);
 char ptarray_same(const POINTARRAY *pa1, const POINTARRAY *pa2);
+char lwpoint_same2d(const LWPOINT *p1, const LWPOINT *p2);
 char lwpoint_same(const LWPOINT *p1, const LWPOINT *p2);
 char lwline_same(const LWLINE *p1, const LWLINE *p2);
 char lwpoly_same(const LWPOLY *p1, const LWPOLY *p2);
diff --git a/liblwgeom/lwgeodetic.c b/liblwgeom/lwgeodetic.c
index 7d9f43f9b..89cf47589 100644
--- a/liblwgeom/lwgeodetic.c
+++ b/liblwgeom/lwgeodetic.c
@@ -2107,8 +2107,8 @@ LWPOINT* lwgeom_project_spheroid(const LWPOINT *r, const SPHEROID *spheroid, dou
 	GEOGRAPHIC_POINT geo_source, geo_dest;
 	POINT4D pt_dest;
 	double x, y;
-	POINTARRAY *pa;
 	LWPOINT *lwp;
+	int has_z, has_m;
 	/* Normalize distance to be positive*/
 	if ( distance < 0.0 ) {
@@ -2129,6 +2129,8 @@ LWPOINT* lwgeom_project_spheroid(const LWPOINT *r, const SPHEROID *spheroid, dou
 	/* Convert to ta geodetic point */
 	x = lwpoint_get_x(r);
 	y = lwpoint_get_y(r);
+	has_z = lwgeom_has_z(lwpoint_as_lwgeom(r));
+	has_m = lwgeom_has_m(lwpoint_as_lwgeom(r));
 	geographic_point_init(x, y, &geo_source);
 	/* Try the projection */
@@ -2140,20 +2142,26 @@ LWPOINT* lwgeom_project_spheroid(const LWPOINT *r, const SPHEROID *spheroid, dou
 	/* Build the output LWPOINT */
-	pa = ptarray_construct(0, 0, 1);
 	pt_dest.x = rad2deg(longitude_radians_normalize(geo_dest.lon));
 	pt_dest.y = rad2deg(latitude_radians_normalize(geo_dest.lat));
-	pt_dest.z = pt_dest.m = 0.0;
-	ptarray_set_point4d(pa, 0, &pt_dest);
-	lwp = lwpoint_construct(r->srid, NULL, pa);
+	pt_dest.z = has_z ? lwpoint_get_z(r) : 0.0;
+	pt_dest.m = has_m ? lwpoint_get_m(r) : 0.0;
+	lwp = lwpoint_make(r->srid, has_z, has_m, &pt_dest);
 	lwgeom_set_geodetic(lwpoint_as_lwgeom(lwp), LW_TRUE);
 	return lwp;
+LWPOINT* lwgeom_project_spheroid_lwpoint(const LWPOINT *from, const LWPOINT *to, const SPHEROID *spheroid, double distance)
+	double azimuth = lwgeom_azumith_spheroid(from, to, spheroid);
+	LWPOINT *lwp = lwgeom_project_spheroid(to, spheroid, distance, azimuth);
+	return lwp;
 * Calculate a bearing (azimuth) given a source and destination point.
-* @param r - location of first point.
+https://accesd.desjardins.ca/coast* @param r - location of first point.
 * @param s - location of second point.
 * @param spheroid - spheroid definition.
 * @return azimuth - azimuth in radians.
diff --git a/liblwgeom/lwpoint.c b/liblwgeom/lwpoint.c
index 3f28c061e..d878c285f 100644
--- a/liblwgeom/lwpoint.c
+++ b/liblwgeom/lwpoint.c
@@ -266,6 +266,39 @@ lwpoint_same(const LWPOINT *p1, const LWPOINT *p2)
 	return ptarray_same(p1->point, p2->point);
+/* check 2d coordinate equality  */
+char
+lwpoint_same2d(const LWPOINT *p1, const LWPOINT *p2)
+	return ptarray_same2d(p1->point, p2->point);
+LWPOINT *
+lwpoint_project_lwpoint(const LWPOINT* lwpoint1, const LWPOINT* lwpoint2, double distance)
+	POINT4D p1, p2, p3;
+	int srid = lwgeom_get_srid((const LWGEOM*)lwpoint1);
+	int hasz = lwgeom_has_z((const LWGEOM*)lwpoint1);
+	int hasm = lwgeom_has_m((const LWGEOM*)lwpoint1);
+	lwpoint_getPoint4d_p(lwpoint1, &p1);
+	lwpoint_getPoint4d_p(lwpoint2, &p2);
+	project_pt_pt(&p1, &p2, distance, &p3);
+	return lwpoint_make(srid, hasz, hasm, &p3);
+LWPOINT *
+lwpoint_project(const LWPOINT* lwpoint1, double distance, double azimuth)
+	POINT4D p1, p2;
+	lwpoint_getPoint4d_p(lwpoint1, &p2);
+	project_pt((POINT2D*)&p1, distance, azimuth, (POINT2D*)&p2);
+	return lwpoint_make(srid, hasz, hasm, &p2);
 LWPOINT*
 lwpoint_force_dims(const LWPOINT *point, int hasz, int hasm, double zval, double mval)
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 6ee9e3426..d1e327cd2 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -2466,3 +2466,49 @@ azimuth_pt_pt(const POINT2D *A, const POINT2D *B, double *d)
 	*d = fmod(2 * M_PI + M_PI / 2 - atan2(B->y - A->y, B->x - A->x), 2 * M_PI);
 	return LW_TRUE;
+ * Azimuth is angle in radians from vertical axis
+int
+project_pt(const POINT2D *P, double distance, double azimuth, POINT2D *R)
+	const double TWOPI = 2.0 * M_PI;
+	double slope;
+	/* Deal with azimuth out of (-360,360) range */
+	int orbits = floor(azimuth / TWOPI);
+	azimuth -= TWOPI * orbits;
+	/* Convert from azimuth to conventional slope */
+	slope = TWOPI - azimuth + M_PI_2;
+	if (slope > 0 && slope >  TWOPI) slope -= TWOPI;
+	if (slope < 0 && slope < -TWOPI) slope += TWOPI;
+	double dx = cos(slope) * distance;
+	double dy = sin(slope) * distance;
+	R->x += dx;
+	R->y += dy;
+	return LW_TRUE;
+int
+project_pt_pt(const POINT4D *A, const POINT4D *B, double distance, POINT4D *R)
+	double len = distance2d_pt_pt((const POINT2D *)A, (const POINT2D *)B);
+	double prop = distance / len;
+	double dx = (B->x - A->x) * prop;
+	double dy = (B->y - A->y) * prop;
+	double dz = (B->z - A->z) * prop;
+	double dm = (B->m - A->m) * prop;
+	R->x += dx;
+	R->y += dy;
+	if (isfinite(dz)) R->z += dz;
+	if (isfinite(dm)) R->m += dm;
+	return LW_TRUE;
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index d903d809d..6692485e7 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -497,6 +497,27 @@ ptarray_same(const POINTARRAY *pa1, const POINTARRAY *pa2)
 	return LW_TRUE;
+char
+ptarray_same2d(const POINTARRAY *pa1, const POINTARRAY *pa2)
+	uint32_t i;
+	if ( FLAGS_GET_ZM(pa1->flags) != FLAGS_GET_ZM(pa2->flags) ) return LW_FALSE;
+	LWDEBUG(5,"dimensions are the same");
+	if ( pa1->npoints != pa2->npoints ) return LW_FALSE;
+	LWDEBUG(5,"npoints are the same");
+	for (i=0; i<pa1->npoints; i++)
+		if ( memcmp(getPoint_internal(pa1, i), getPoint_internal(pa2, i), sizeof(POINT2D)) )
+			return LW_FALSE;
+		LWDEBUGF(5,"point #%d is the same",i);
+	return LW_TRUE;
 POINTARRAY *
 ptarray_addPoint(const POINTARRAY *pa, uint8_t *p, size_t pdims, uint32_t where)
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index 6da02e208..9a61d7a7a 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -600,6 +600,13 @@ CREATE OR REPLACE FUNCTION ST_Project(geog geography, distance float8, azimuth f
 	LANGUAGE 'c' IMMUTABLE PARALLEL SAFE
 	_COST_MEDIUM;
+-- Availability: 3.4.0
+CREATE OR REPLACE FUNCTION ST_Project(geog_from geography, geog_to geography, distance float8)
+	RETURNS geography
+	AS 'MODULE_PATHNAME','geography_project_geography'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_MEDIUM;
 -- Availability: 2.0.0
 CREATE OR REPLACE FUNCTION ST_Azimuth(geog1 geography, geog2 geography)
 	RETURNS float8
diff --git a/postgis/geography_measurement.c b/postgis/geography_measurement.c
index 1911472c3..6bda676b3 100644
--- a/postgis/geography_measurement.c
+++ b/postgis/geography_measurement.c
@@ -1027,6 +1027,77 @@ Datum geography_project(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(g_out);
+** geography_project_geography(geog1, geog2, distance, azimuth)
+** returns point of projection given from/pt points,
+** azimuth in radians (bearing) and distance in meters
+PG_FUNCTION_INFO_V1(geography_project_geography);
+Datum geography_project_geography(PG_FUNCTION_ARGS)
+	LWGEOM *lwgeom1, *lwgeom2;
+	LWPOINT *lwp1, *lwp2, *lwp3;
+	GSERIALIZED *g1, *g2, *g3;
+	double distance;
+	SPHEROID s;
+	/* Get our geometry object loaded into memory. */
+	g1 = PG_GETARG_GSERIALIZED_P(0);
+	g2 = PG_GETARG_GSERIALIZED_P(1);
+	if ( gserialized_get_type(g1) != POINTTYPE ||
+		 gserialized_get_type(g2) != POINTTYPE )
+		elog(ERROR, "ST_Project(geography) is only valid for point inputs");
+		PG_RETURN_NULL();
+	distance = PG_GETARG_FLOAT8(2); /* Distance in meters */
+	/* Handle the zero distance case */
+	if ( FP_EQUALS(distance, 0.0) )
+		PG_RETURN_POINTER(g2);
+	lwgeom1 = lwgeom_from_gserialized(g1);
+	lwgeom2 = lwgeom_from_gserialized(g2);
+	/* EMPTY things cannot be projected from */
+	if ( lwgeom_is_empty(lwgeom1) || lwgeom_is_empty(lwgeom2) )
+		lwgeom_free(lwgeom1);
+		lwgeom_free(lwgeom2);
+		elog(ERROR, "ST_Project(geography) cannot project from an empty point");
+		PG_RETURN_NULL();
+	/* Initialize spheroid */
+	spheroid_init_from_srid(lwgeom_get_srid(lwgeom1), &s);
+	/* Calculate the length */
+	lwp1 = lwgeom_as_lwpoint(lwgeom1);
+	lwp2 = lwgeom_as_lwpoint(lwgeom2);
+	lwp3 = lwgeom_project_spheroid_lwpoint(lwp1, lwp2, &s, distance);
+	/* Something went wrong... */
+	if ( lwp3 == NULL )
+		elog(ERROR, "lwgeom_project_spheroid_lwpoint returned null");
+		PG_RETURN_NULL();
+	/* Clean up, but not all the way to the point arrays */
+	g3 = geography_serialize(lwpoint_as_lwgeom(lwp3));
+	lwpoint_free(lwp3);
+	PG_FREE_IF_COPY(g1, 0);
+	PG_FREE_IF_COPY(g2, 1);
+	PG_RETURN_POINTER(g3);
 ** geography_azimuth(GSERIALIZED *g1, GSERIALIZED *g2)
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 72e61bf77..4f22b76a9 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -105,6 +105,8 @@ Datum LWGEOM_setpoint_linestring(PG_FUNCTION_ARGS);
 Datum LWGEOM_asEWKT(PG_FUNCTION_ARGS);
 Datum LWGEOM_hasBBOX(PG_FUNCTION_ARGS);
 Datum LWGEOM_azimuth(PG_FUNCTION_ARGS);
+Datum geometry_project_direction(PG_FUNCTION_ARGS);
+Datum geometry_project_geometry(PG_FUNCTION_ARGS);
 Datum LWGEOM_angle(PG_FUNCTION_ARGS);
 Datum LWGEOM_affine(PG_FUNCTION_ARGS);
 Datum LWGEOM_longitude_shift(PG_FUNCTION_ARGS);
@@ -2573,6 +2575,82 @@ Datum LWGEOM_azimuth(PG_FUNCTION_ARGS)
 	PG_RETURN_FLOAT8(result);
+ * Project a new point from a start point, direction and distance.
+ * ST_Project(geometry, distance, azimuth)
+ * Azimuth is measured in radians, clockwise from north.
+ * Distance is in SRID units.
+ * Geometry must be point.
+PG_FUNCTION_INFO_V1(geometry_project_direction);
+	GSERIALIZED *geom1, *geom2;
+	LWPOINT *lwpoint1, *lwpoint2;
+	double distance, azimuth;
+	geom1 = PG_GETARG_GSERIALIZED_P(0);
+	distance = PG_GETARG_FLOAT8(1);
+	azimuth = PG_GETARG_FLOAT8(2);
+	lwgeom1 = lwgeom_from_gserialized(geom1);
+	lwpoint1 = lwgeom_as_lwpoint(lwgeom1);
+	if (!lwpoint1)
+		lwpgerror("Argument must be POINT geometry");
+	if (lwgeom_is_empty(lwgeom1))
+		PG_RETURN_NULL();
+	lwpoint2 = lwpoint_project(lwpoint1, distance, azimuth);
+	lwgeom2 = lwpoint_as_lwgeom(lwpoint2);
+	geom2 = geometry_serialize(lwgeom2);
+	PG_RETURN_POINTER(geom2);
+PG_FUNCTION_INFO_V1(geometry_project_geometry);
+	GSERIALIZED *geom1, *geom2, *geom3;
+	LWPOINT *lwpoint1, *lwpoint2, *lwpoint3;
+	LWGEOM *lwgeom1, *lwgeom2, *lwgeom3;
+	double distance;
+	geom2 = PG_GETARG_GSERIALIZED_P(1);
+	lwgeom2 = lwgeom_from_gserialized(geom2);
+	lwpoint2 = lwgeom_as_lwpoint(lwgeom2);
+	if (!(lwpoint1 && lwpoint2))
+		lwpgerror("Arguments must be POINT geometries");
+	if (lwgeom_is_empty(lwgeom1) || lwgeom_is_empty(lwgeom2))
+		PG_RETURN_NULL();
+	if (lwpoint_same2d(lwpoint1, lwpoint2))
+	lwpoint3 = lwpoint_project_lwpoint(lwpoint1, lwpoint2, distance);
+	lwgeom3 = lwpoint_as_lwgeom(lwpoint3);
+	geom3 = geometry_serialize(lwgeom3);
+	PG_RETURN_POINTER(geom3);
  * Compute the angle defined by 3 points or the angle between 2 vectors
  * defined by 4 points
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 55d50df45..5e9275c74 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1390,6 +1390,20 @@ CREATE OR REPLACE FUNCTION ST_azimuth(geom1 geometry, geom2 geometry)
 	_COST_LOW;
+CREATE OR REPLACE FUNCTION ST_Project(geom1 geometry, distance float8, azimuth float8)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'geometry_project_direction'
+	_COST_LOW;
+CREATE OR REPLACE FUNCTION ST_Project(geom1 geometry, geom2 geometry, distance float8)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'geometry_project_geometry'
+	_COST_LOW;
 -- Availability: 2.5.0
 CREATE OR REPLACE FUNCTION ST_Angle(pt1 geometry, pt2 geometry, pt3 geometry, pt4 geometry default 'POINT EMPTY'::geometry)
 	RETURNS float8
diff --git a/regress/core/measures.sql b/regress/core/measures.sql
index 58072ca67..465578177 100644
--- a/regress/core/measures.sql
+++ b/regress/core/measures.sql
@@ -290,3 +290,19 @@ SELECT '#4328.3', ST_Intersects('TIN(((0 0,1 0,0 1,0 0)))'::geometry, 'TRIANGLE(
 SELECT '#4328.4', ST_Intersects('TIN(((0 0,1 0,0 1,0 0)))'::geometry, 'POLYGON((.1 .1, .2 .2, .2 .1, .1 .1))'::geometry), ST_3DIntersects('TIN(((0 0,1 0,0 1,0 0)))'::geometry, 'POLYGON((.1 .1, .2 .2, .2 .1, .1 .1))'::geometry);
 SELECT '#4328.5', ST_Intersects('TIN(((0 0,3 0,0 3,0 0)))'::geometry, 'CIRCULARSTRING(1.1 1.1, 1.2 1.2, 1.2 1.1)'::geometry), ST_3DIntersects('TIN(((0 0,3 0,0 3,0 0)))'::geometry, 'CIRCULARSTRING(1.1 1.1, 1.2 1.2, 1.2 1.1)'::geometry);
 SELECT '#4328.6', ST_Intersects('TIN(((0 0,3 0,0 3,0 0)))'::geometry, 'CURVEPOLYGON(CIRCULARSTRING(1.1 1.1, 1.2 1.2, 1.2 1.1, 1.2 1.2, 1.1 1.1))'::geometry), ST_3DIntersects('TIN(((0 0,3 0,0 3,0 0)))'::geometry, 'CURVEPOLYGON(CIRCULARSTRING(1.1 1.1, 1.2 1.2, 1.2 1.1, 1.2 1.2, 1.1 1.1))'::geometry);
+SELECT 'st_project.01', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 1, 0), 0.1), 2);
+SELECT 'st_project.02', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 1, pi()), 0.1), 2);
+SELECT 'st_project.03', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 1, pi()/2), 0.1), 2);
+SELECT 'st_project.04', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 1, 3*pi()/2), 0.1), 2);
+SELECT 'st_project.05', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 1, pi()/4), 0.001), 3);
+SELECT 'st_project.06', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 1, pi()+pi()/4), 0.001), 3);
+SELECT 'st_project.07', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 0, 0), 0.001), 3);
+SELECT 'st_project.11', ST_AsText(ST_SnapToGrid(ST_Project('POINT(1 0)'::geometry, 'POINT(0 0)'::geometry, 1), 0.1), 2);
+SELECT 'st_project.12', ST_AsText(ST_SnapToGrid(ST_Project('POINT(-1 0)'::geometry, 'POINT(0 0)'::geometry, 1), 0.1), 2);
+SELECT 'st_project.13', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 1)'::geometry, 'POINT(0 0)'::geometry, 1), 0.1), 2);
+SELECT 'st_project.14', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 -1)'::geometry, 'POINT(0 0)'::geometry, 1), 0.1), 2);
+SELECT 'st_project.15', ST_AsText(ST_SnapToGrid(ST_Project('POINT(1 1)'::geometry, 'POINT(0 0)'::geometry, 1), 0.001), 3);
+SELECT 'st_project.16', ST_AsText(ST_SnapToGrid(ST_Project('POINT(-1 -1)'::geometry, 'POINT(0 0)'::geometry, 1), 0.001), 3);
+SELECT 'st_project.17', ST_AsText(ST_SnapToGrid(ST_Project('POINT(0 0)'::geometry, 'POINT(0 0)'::geometry, 1), 0.001), 3);
diff --git a/regress/core/measures_expected b/regress/core/measures_expected
index 7ff9f1307..a9114589c 100644
--- a/regress/core/measures_expected
+++ b/regress/core/measures_expected
@@ -79,3 +79,17 @@ NOTICE:  One or both of the geometries is missing z-value. The unknown z-value w
 #4328.5|t|t
 NOTICE:  One or both of the geometries is missing z-value. The unknown z-value will be regarded as "any value"
 #4328.6|t|t
+st_project.01|POINT(0 1)
+st_project.02|POINT(0 -1)
+st_project.03|POINT(1 0)
+st_project.04|POINT(-1 0)
+st_project.05|POINT(0.707 0.707)
+st_project.06|POINT(-0.707 -0.707)
+st_project.07|POINT(0 0)
+st_project.11|POINT(-1 0)
+st_project.12|POINT(1 0)
+st_project.13|POINT(0 -1)
+st_project.14|POINT(0 1)
+st_project.15|POINT(-0.707 -0.707)
+st_project.16|POINT(0.707 0.707)
+st_project.17|POINT(0 0)
Summary of changes:
 NEWS                             |  2 ++
 doc/reference_measure.xml        | 57 ++++++++++++++++++++++-------
 liblwgeom/liblwgeom.h.in         |  7 ++++
 liblwgeom/liblwgeom_internal.h   |  8 +++++
 liblwgeom/lwgeodetic.c           | 20 +++++++----
 liblwgeom/lwpoint.c              | 33 +++++++++++++++++
 liblwgeom/measures.c             | 46 ++++++++++++++++++++++++
 liblwgeom/ptarray.c              | 21 +++++++++++
 postgis/geography.sql.in         |  7 ++++
 postgis/geography_measurement.c  | 71 ++++++++++++++++++++++++++++++++++++
 postgis/lwgeom_functions_basic.c | 78 ++++++++++++++++++++++++++++++++++++++++
 postgis/postgis.sql.in           | 14 ++++++++
 regress/core/measures.sql        | 16 +++++++++
 regress/core/measures_expected   | 14 ++++++++
 14 files changed, 375 insertions(+), 19 deletions(-)
hooks/post-receive
