[postgis-tickets] [PostGIS] #5341: debbie failing on raster upgrade from 3.2, 3.1 to 3.4
PostGIS trac at osgeo.org
Tue Mar 7 01:52:26 PST 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 I'm trying to reproduce this locally but don't seem to be able to.
 The problem should be triggered by ST_Metadata returning NULL for some of
 the parameters passed to ST_AsRaster, which would then return NULL. If
 that's the case the current code would raise a DEBUG. Any chance you have
 those DEBUG logs activated in debbie's log ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5341#comment:10>
