[postgis-tickets] [PostGIS] #5353: EPSG:5070 mismatch between spatial_ref_sys and PROJ
PostGIS trac at osgeo.org
Tue Mar 7 22:14:11 PST 2023
  Reporter:  jbkoch   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.1.9
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Comment (by jbkoch):
 @robe Thank you for the information as I was not aware of the precedence
 used. This is somewhat of a special case as this is happening in the
 official Amazon RDS Postgresql instances of which I have no control over
 packaging. It would appear that something is going wrong in their
 dependency stack to not have the correct projection info in proj.db for
 PROJ 8.0.1. I am not sure who manages that project or who would be the
 correct person to contact about this issue?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5353#comment:4>
