[postgis-tickets] [PostGIS] #5353: EPSG:5070 mismatch between spatial_ref_sys and PROJ
PostGIS trac at osgeo.org
Fri Mar 10 19:14:47 PST 2023
  Reporter:  jbkoch   |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 3.1.9
 Component:  postgis  |    Version:  3.1.x
Resolution:  wontfix  |   Keywords:
Comment (by jbkoch):
 Replying to [comment:7 robe]:
 > Replying to [comment:4 jbkoch]:
 > > @robe Thank you for the information as I was not aware of the
 precedence used. This is somewhat of a special case as this is happening
 in the official Amazon RDS Postgresql instances of which I have no control
 over packaging. It would appear that something is going wrong in their
 dependency stack to not have the correct projection info in proj.db for
 PROJ 8.0.1. I am not sure who manages that project or who would be the
 correct person to contact about this issue?
 > At jbkoch, are you saying the 8.0.1 on Amazon RDS is wrong?  I thought
 you were complaining about the proj 5.2.0 on your 3.1.5 install which
 would be wrong, because we ship a different proj4, and your 3.1.5 is using
 proj 5.2.0, which does use the proj4text in spatial_ref_sys.
 Yes, this is what I believe to be the issue. The 3.1.5 install with the
 older proj 5.2.0 had the "correct/reference" values and when I upgraded to
 the 3.1.7 install with the newer proj 8.0.1, the values were off. I was
 able to match the old values by using the PROJ.4 string which I grabbed
 from a local proj 8.0.1 build (more details below).
 > If there is an issue with what AMZ is shipping, I can talk with the AMZ
 packaging group about that.
 I would very much appreciate that if you too believe there is a potential
 issue here.
 > When you said
 > > I was able to fix the issue by using the PROJ.4 string defined in PROJ
 8.0.1
 > Copy this where?  If you updated your spatial_ref_sys on your AMZ RDS
 (running PROJ 8.0.1) with this proj4text, it shouldn't have made a
 difference as it would still be using the proj.db shipped with PROJ, and
 would only fall back on spatial_ref_sys, if that entry was entirely
 missing in the proj.db that Amazon ships.
 > On my Amazon RDS database running PROJ 8.0.1:
 > POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150" GEOS="3.9.1-CAPI-1.14.2"
 PROJ="8.0.1" GDAL="GDAL 3.4.3, released 2022/04/22" LIBXML="2.9.1"
 LIBJSON="0.15" LIBPROTOBUF="1.3.2" WAGYU="0.5.0 (Internal)" TOPOLOGY
 RASTER
 > I get:
 > select
 >   st_astext( geom_5070 )
 > from st_geomfromtext(
 >   'POLYGON((
 >     -94.23933949466884 41.46010784655825,
 >     -94.23902022173033 41.46011128632304,
 >     -94.23901390824655 41.45984441537449,
 >     -94.23933317987697 41.45984097564519,
 >     -94.23933949466884 41.46010784655825))', 4326 ) geom_4326,
 >     st_transform( geom_4326, 5070 ) geom_5070;
 > POLYGON((145953.2894197142 2051852.3578379445,145979.74635016784
 2051853.2334285255,145980.8230537888 2051823.3784043754,145954.36613142194
 2051822.5028163139,145953.2894197142 2051852.3578379445))
 > Which corresponds to your second answer.
 > If I run:
 >     UPDATE spatial_ref_sys SET proj4text = '+proj=aea +lat_0=23
 +lon_0=-96 +lat_1=29.5 +lat_2=45.5 +x_0=0 +y_0=0 +ellps=GRS80
 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs +type=crs'
 >     WHERE srid=5070;
 > and check the results, as I would expect, I get the same answer:
 > This should only make a difference if you are updating your 3.1.5
 instance which ships with PROJ 5.2.0 (predates the existence of the new
 proj api, so uses the spatial_ref_sys.proj4text)
 If you put the 8.0.1 PROJ.4 string into the st_transform function on the
 3.1.7 instance as so:
 select
   'POLYGON((
     st_transform( geom_4326, '+proj=aea +lat_0=23 +lon_0=-96 +lat_1=29.5
 +lat_2=45.5 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m
 +no_defs +type=crs' ) geom_5070;
 You should get the old/matched results back:
 POLYGON((145953.8164326792 2051852.6976375678,145980.27310072441
 2051853.5729657637,145981.34988068073
 2051823.7175862629,145954.89322071325 2051822.842260323,145953.8164326792
 2051852.6976375678))
 I was able to make this permanent by changing the `auth_name` column to
 something other than "EPSG" in the `spatial_ref_sys` table, i.e.:
 UPDATE "public"."spatial_ref_sys" SET "auth_name" = 'JK', "proj4text" =
 '+proj=aea +lat_0=23 +lon_0=-96 +lat_1=29.5 +lat_2=45.5 +x_0=0 +y_0=0
 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs +type=crs' WHERE
 "srid" = 5070;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5353#comment:8>
