[postgis-tickets] [PostGIS] #5353: EPSG:5070 mismatch between spatial_ref_sys and PROJ
PostGIS trac at osgeo.org
Fri Mar 10 19:58:47 PST 2023
  Reporter:  jbkoch   |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 3.1.9
 Component:  postgis  |    Version:  3.1.x
Resolution:  wontfix  |   Keywords:
Comment (by jbkoch):
 So just to make sure there wasn't something going on with PROJ itself, I
 build the same dependency stack from source on a local machine:
 PROJ v8.0.1
 GEOS v3.9.1
 GDAL v3.4.3
 And I ran the following command (added the input and output files as
 attachments):
 ogr2ogr -t_srs EPSG:5070 1884810.5070.ogr2ogr.gpkg 1884810.4326.gpkg
 I got the same older matching results back:
 POLYGON((145953.8164326792 2051852.6976375678,145980.27310072441
 2051853.5729657637,145981.34988068073
 2051823.7175862629,145954.89322071325 2051822.842260323,145953.8164326792
 2051852.6976375678))
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5353#comment:9>
