[postgis-tickets] [PostGIS] #5355: PostGIS 3, ST_DWithin Query - "lwgeom_distance_spheroid returned negative!" by changing third arg? Postgres 11, Ubuntu 20.04
PostGIS trac at osgeo.org
Wed Mar 15 09:19:20 PDT 2023
 Reporter:  dchun    |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.3.3
Component:  postgis  |    Version:  3.3.x
 Keywords:           |
 The unexpected error:
 `lwgeom_distance_spheroid returned negative!`
 By making a tiny change in the third argument (distance) to ST_DWithin, we
 get an error in one version but not another. In other words, by changing
 the distance by a tiny fraction: 3754219.5 -> 3754219.6 we get the error.
 This distance where it starts failing is different for different POINTs.
 Additionally, geometry or geography makes no difference, it only changes
 the value where the distance error occurs.
 It does not happen on Ubuntu 16.04, Postgres 11, PostGIS 2.5.
 I've tried to isolate it here:
 ```FAILING ON Ubuntu 20.04 PostGIS 3.3:```
 $ lsb_release -a
 No LSB modules are available.
 Distributor ID: Ubuntu
 Description:    Ubuntu 20.04.5 LTS
 Release:        20.04
 Codename:       focal
 {{{#!sql
 psql (11.19 (Ubuntu 11.19-1.pgdg20.04+1))
 # SELECT VERSION();
        version
  PostgreSQL 11.19 (Ubuntu 11.19-1.pgdg20.04+1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, 64-bit
 (1 row)
 # SELECT postgis_full_version();
  POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="110" GEOS="3.9.1-CAPI-1.14.2"
 PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3"
 WAGYU="0.5.0 (Internal)"
 (1 row)
 # SELECT PostGIS_Liblwgeom_Version();
  postgis_liblwgeom_version
  3.3.2 4975da8
 (1 row)
 # SELECT ST_DWithin('SRID=4326;POINT(-74.8456
 40.1752)','SRID=4326;POINT(-118.493 34.0172)', 3754219.5, true) as
 is_within;
  is_within
  f
 (1 row)
 40.1752)','SRID=4326;POINT(-118.493 34.0172)', 3754219.6, true) as
 is_within;
 ERROR:  lwgeom_distance_spheroid returned negative!
 CONTEXT:  SQL function "st_dwithin" statement 1
 ```SUCCESSFUL ON Ubuntu 16.04 PostGIS 2.5:```
 lsb_release -a
 Description:    Ubuntu 16.04.6 LTS
 Release:        16.04
 Codename:       xenial
 {{{#!sql
 (12.1 (Ubuntu 12.1-1.pgdg16.04+1), server 11.6 (Ubuntu
 11.6-1.pgdg16.04+1))
 You are now connected to database "mydatabasewithpostgisinit" as user
 "postgres".
 =# SELECT VERSION();
        version
  PostgreSQL 11.6 (Ubuntu 11.6-1.pgdg16.04+1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 5.4.0-6ubuntu1~16.04.12) 5.4.0 20160609, 64-bit
 (1 row)
 =# SELECT postgis_full_version();
  POSTGIS="2.5.3 r17699" [EXTENSION] PGSQL="110" GEOS="3.7.1-CAPI-1.11.1
 27a5e771" PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL 1.11.3, released
 2015/09/16" LIBXML="2.9.3" LIBJSON="0.11.99" LIBPROTOBUF="1.2.1" RASTER
 (1 row)
 =# SELECT PostGIS_Liblwgeom_Version();
  2.5.3 r17699
 (1 row)
 =# SELECT ST_DWithin('SRID=4326;POINT(-74.8456
 is_within;
  is_within
  f
 (1 row)
 is_within;
  is_within
  f
 (1 row)
 40.1752)','SRID=4326;POINT(-118.493 34.0172)', 111113754219.6, true) as
 is_within;
  is_within
  t
 You can see, for a huge distance, in the working version, it still doesn't
 fail on 2.5.
 Is this a bug? Or has something changed? I haven't been able to find any
 explanation for it.
 Thanks!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5355>
