[postgis-tickets] [PostGIS] #5355: PostGIS 3, ST_DWithin Query - "lwgeom_distance_spheroid returned negative!" by changing third arg? Postgres 11, Ubuntu 20.04
PostGIS trac at osgeo.org
Wed Mar 15 20:59:28 PDT 2023
  Reporter:  dchun    |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS Packaging
 Component:  postgis  |    Version:  3.3.x
Resolution:  wontfix  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
 * milestone:  PostGIS 3.3.3 => PostGIS Packaging
Comment:
 From IRC reports, this seems to be an issue with mixing apt.postgresql.org
 (postgis) and then getting proj and other stuff from ubuntugis, that even
 though PostGIS is using 6.3, it's hitching a ride on the proj 7 data from
 ubuntugis, which seems incompatible.
 So going to mark this as a wontfix and a PostGIS packaging issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5355#comment:4>
