[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-687-gbfc0ecc50
Tue Mar 21 16:48:37 PDT 2023
the project "PostGIS".
       via  bfc0ecc50bd29c27af1fdd6aa56b2754f93a5d51 (commit)
      from  0a7d3bc20498532464c9064a4c75912f842f565f (commit)
revisions in full, below.
commit bfc0ecc50bd29c27af1fdd6aa56b2754f93a5d51
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Mar 21 19:47:42 2023 -0400
    Change ST_3DConvexHull to check area
    The order of polygon patches and starting points of polygons
    is not consistent across sfcgal versions, per report on IRC
diff --git a/sfcgal/regress/regress_sfcgal.sql b/sfcgal/regress/regress_sfcgal.sql
index 582ed2728..99141b887 100644
--- a/sfcgal/regress/regress_sfcgal.sql
+++ b/sfcgal/regress/regress_sfcgal.sql
@@ -31,7 +31,7 @@ SELECT 'ST_MinkowskiSum', ST_AsText(ST_MinkowskiSum('LINESTRING(0 0,4 0)','POLYG
 SELECT 'ST_StraightSkeleton', ST_AsText(ST_StraightSkeleton('POLYGON((1 1,2 1,2 2,1 2,1 1))'));
 SELECT 'ST_ConstrainedDelaunayTriangles', ST_AsText(ST_ConstrainedDelaunayTriangles('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((2 2, 2 -2, 4 0, 2 2)))'));
 SELECT 'postgis_sfcgal_noop', ST_NPoints(postgis_sfcgal_noop(ST_Buffer('POINT(0 0)', 5)));
-SELECT 'ST_3DConvexHull', ST_AsText(ST_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'));
+SELECT 'ST_3DConvexHull', ST_3DArea(ST_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'))::numeric(10,4);
 -- Result of ST_3DUnion is not deterministic and cannot be checked by
 -- simple string comparison
 SELECT 'ST_3DUnion', ABS(ST_Volume(ST_3DUnion(g1, g2)) - 40) < 1e-12 FROM (
diff --git a/sfcgal/regress/regress_sfcgal_expected b/sfcgal/regress/regress_sfcgal_expected
index 511be0b0f..5dec99551 100644
--- a/sfcgal/regress/regress_sfcgal_expected
+++ b/sfcgal/regress/regress_sfcgal_expected
@@ -11,6 +11,6 @@ ST_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
 ST_StraightSkeleton|MULTILINESTRING((1 1,1.5 1.5),(2 1,1.5 1.5),(2 2,1.5 1.5),(1 2,1.5 1.5))
 ST_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2 2)))
 postgis_sfcgal_noop|33
-ST_3DConvexHull|POLYHEDRALSURFACE Z (((1 5 3,9 5 3,0 0 5,1 5 3)),((1 5 3,0 0 5,5 7 6,1 5 3)),((5 7 6,5 7 5,1 5 3,5 7 6)),((0 0 5,6 3 5,5 7 6,0 0 5)),((6 3 5,9 5 3,5 7 6,6 3 5)),((0 0 5,9 5 3,6 3 5,0 0 5)),((9 5 3,5 7 5,5 7 6,9 5 3)),((1 5 3,5 7 5,9 5 3,1 5 3)))
+ST_3DConvexHull|80.9227
 ST_3DUnion|t
 ST_3DUnion (aggregate)|t
Summary of changes:
 sfcgal/regress/regress_sfcgal.sql      | 2 +-
 sfcgal/regress/regress_sfcgal_expected | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
