[postgis-tickets] [PostGIS] #5360: Cirrus CI failing on proj tests
PostGIS trac at osgeo.org
Sun Mar 26 18:43:57 PDT 2023
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 3.3.3
 Component:  buildbots  |    Version:  3.3.x
Resolution:  fixed      |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"887efa9ed30f9d2350b58e3a6c9e0e9464df6498/git" 887efa9/git]:
 {{{#!CommitTicketReference repository="git"
 revision="887efa9ed30f9d2350b58e3a6c9e0e9464df6498"
 Add projsync steps to fix cirrus proj failures.
 Add verbose to make check so can see failures
 Closes #5360 for 3.3.3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5360#comment:3>
