[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-694-g7d7c40306
Tue Mar 28 15:58:29 PDT 2023
the project "PostGIS".
       via  7d7c403069dd7bb8402d99d2c3a7df6106eafbef (commit)
      from  f43042025de04b44af6e3ee70bd5204177fd5559 (commit)
revisions in full, below.
commit 7d7c403069dd7bb8402d99d2c3a7df6106eafbef
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Mar 28 15:58:06 2023 -0700
    Add note on what the default validity algorithm is
diff --git a/doc/reference_validation.xml b/doc/reference_validation.xml
index af36e2e62..9dbd71a6a 100644
--- a/doc/reference_validation.xml
+++ b/doc/reference_validation.xml
@@ -341,6 +341,7 @@ SELECT ST_IsValidReason('LINESTRING(220227 150406,2220227 150407,222020 150410)'
     The <varname>params</varname> argument can be used to supply an options
     string to select the method to use for building valid geometry.
     The options string is in the format "method=linework|structure keepcollapsed=true|false".
+    If no "params" argument is provided, the "linework" algorithm will be used as the default.
     </para>
     <para>The "method" key has two values.</para>
Summary of changes:
 doc/reference_validation.xml | 1 +
 1 file changed, 1 insertion(+)
hooks/post-receive
