[postgis-tickets] [PostGIS] #5341: debbie failing on raster upgrade from 3.2, 3.1 to 3.4
PostGIS trac at osgeo.org
Wed Mar 29 16:25:25 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"0dae51d2620920f2a21bcb5feaa59b020db83a38/git" 0dae51d/git]:
 {{{#!CommitTicketReference repository="git"
 revision="0dae51d2620920f2a21bcb5feaa59b020db83a38"
 Turn off unpackaged -> packaged tests as well
 References #5341 try to quiet debbie's failures
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5341#comment:18>
