[postgis-tickets] [PostGIS] #5341: debbie failing on raster upgrade from 3.2, 3.1 to 3.4
PostGIS trac at osgeo.org
Wed Mar 29 17:06:52 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 It could be addrasterconstraints() behaviour changed in 3.3 and our use of
 it from the before-upgrade-raster hook is incompatible. The idea of that
 call before upgrade was to test the fix for #5338
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5341#comment:20>
