[postgis-tickets] [PostGIS] #5341: debbie failing on raster upgrade from 3.2, 3.1 to 3.4
PostGIS trac at osgeo.org
Wed Mar 29 17:25:20 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 Note I still cannot reproduce locally:
 > ../regress/run_test.pl -v --extension --raster --upgrade-path
 unpackaged3.2--:auto --before-upgrade-script ../raster/test/regress/hooks
 /hook-before-upgrade-raster.sql --after-upgrade-script
 ../raster/test/regress/hooks/hook-after-upgrade-raster.sql
 ../raster/test/regress/box3d.sql
 Works fine for me, and /tmp/pgis_reg/regress_log nicely says:
 psql:../raster/test/regress/hooks/hook-before-upgrade-raster.sql:33:
 NOTICE:  Adding coverage tile constraint required for regular blocking
 NOTICE:  Adding spatially unique constraint required for regular blocking
  addrasterconstraints
  t
 (1 row)
 What would the possible reasons why ST_AsRaster would return NULL in
 Debbie ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5341#comment:22>
