[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-748-g705fc8743
Thu May 4 08:23:57 PDT 2023
the project "PostGIS".
       via  705fc8743543779e6d74014a681249e0ccbdc129 (commit)
       via  1d263dc2ee69514f67afb1f8115877329aad13a7 (commit)
      from  495b926e31f0bbef0980da4130f2e14fbdf911ab (commit)
revisions in full, below.
commit 705fc8743543779e6d74014a681249e0ccbdc129
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu May 4 17:17:06 2023 +0200
    Tweak interrupt_relate test to catch interruption in ST_Intersects
    That function became very fast so the result was obtained before
    reaching the statement timeout time
diff --git a/regress/core/interrupt_relate.sql b/regress/core/interrupt_relate.sql
index 0fd2b4767..466baa867 100644
--- a/regress/core/interrupt_relate.sql
+++ b/regress/core/interrupt_relate.sql
@@ -1,3 +1,5 @@
+set client_min_messages to WARNING;
 CREATE TEMPORARY TABLE _time AS SELECT now() t;
 CREATE FUNCTION _timecheck(label text, tolerated interval) RETURNS text
@@ -50,7 +52,9 @@ SELECT _timecheck('crosses', '200ms');
 select ST_Equals(g,st_reverse(g)) from _inputs WHERE id = 1; -- 6+ seconds
 SELECT _timecheck('equals', '200ms');
-select ST_Intersects(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+-- NOTE: intersects became very fast, so we segmentize
+--       input to make it slower
+select ST_Intersects(g,ST_Segmentize(g,1e-4)) from _inputs WHERE id = 1; -- 6+ seconds
 SELECT _timecheck('intersects', '200ms');
 select ST_Overlaps(g,g) from _inputs WHERE id = 1; -- 6+ seconds
@@ -60,3 +64,4 @@ select ST_Relate(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 SELECT _timecheck('relate', '200ms');
 DROP FUNCTION _timecheck(text, interval);
+DROP TABLE _inputs;
commit 1d263dc2ee69514f67afb1f8115877329aad13a7
Date:   Thu May 4 17:21:24 2023 +0200
    Let PostgreSQL write the interruption error message
    Closes #5365
    Reverts 17708aa3c2
diff --git a/postgis/lwgeom_geos.h b/postgis/lwgeom_geos.h
index 2fb5cf93c..3f8d24519 100644
--- a/postgis/lwgeom_geos.h
+++ b/postgis/lwgeom_geos.h
@@ -57,10 +57,7 @@ uint32_t array_nelems_not_null(ArrayType* array);
 #define HANDLE_GEOS_ERROR(label) \
-		if (strstr(lwgeom_geos_errmsg, "InterruptedException")) \
-			ereport(ERROR, \
-				(errcode(ERRCODE_QUERY_CANCELED), errmsg("canceling statement due to user request"))); \
-		else \
+		if (!strstr(lwgeom_geos_errmsg, "InterruptedException")) \
 			lwpgerror("%s: %s", (label), lwgeom_geos_errmsg); \
 		PG_RETURN_NULL(); \
Summary of changes:
 postgis/lwgeom_geos.h             | 5 +----
 regress/core/interrupt_relate.sql | 7 ++++++-
 2 files changed, 7 insertions(+), 5 deletions(-)
hooks/post-receive
