[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-749-g1f6327f7c
Thu May 4 09:50:39 PDT 2023
the project "PostGIS".
       via  1f6327f7caa84c093cfec900c433b44aba02a0ab (commit)
      from  705fc8743543779e6d74014a681249e0ccbdc129 (commit)
revisions in full, below.
commit 1f6327f7caa84c093cfec900c433b44aba02a0ab
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu May 4 18:49:43 2023 +0200
    Tweak the interrupt test for ST_Segmentize to avoid early exit
    There's a new check in ST_Segmentize to avoid too many segments,
    I found a max length parameter which is still able to trigger
    interruption on my system.
diff --git a/regress/core/interrupt.sql b/regress/core/interrupt.sql
index e44c760c9..57e1ddea4 100644
--- a/regress/core/interrupt.sql
+++ b/regress/core/interrupt.sql
@@ -23,7 +23,7 @@ $$ LANGUAGE 'plpgsql' VOLATILE;
 SET statement_timeout TO 100;
 -- would run for many seconds if uninterruptible...
-SELECT ST_Segmentize(ST_MakeLine(ST_Point(4,39), ST_Point(1,41)), 1e-100);
+SELECT 'segmentize', ST_NPoints(ST_Segmentize(ST_MakeLine(ST_Point(4,39), ST_Point(1,41)), 1e-8));
 SELECT _timecheck('segmentize', '250ms');
 SET statement_timeout TO 0;
 -- Not affected by old timeout
Summary of changes:
 regress/core/interrupt.sql | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
