[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-752-g41a3acb8d
Thu May 4 17:58:30 PDT 2023
the project "PostGIS".
       via  41a3acb8dbabb93986a9c4d0a484f780e3035351 (commit)
      from  b1f1d964109844728da87a231701036be1461303 (commit)
revisions in full, below.
commit 41a3acb8dbabb93986a9c4d0a484f780e3035351
Author: Regina Obe <lr at pcorp.us>
Date:   Thu May 4 20:57:39 2023 -0400
    commit 3d9eb671319b29d6244af592b3158e13bf915f3e
    Author: Sandro Santilli <strk at kbt.io>
    Date:   Thu May 4 21:20:15 2023 +0200
        Stop disabling interrupt tests in all bots
    commit e1456ebb379ab5c183ca487f950cba0ed119632f
    Date:   Thu May 4 20:42:10 2023 +0200
        Enable interrupt tests by default
diff --git a/.cirrus.yml b/.cirrus.yml
index 8e27dd7fb..26b3c8ab9 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -17,7 +17,7 @@ task:
     - find . -name "*.pl" | xargs sed -i -r 's|/usr/bin/perl|/usr/bin/env perl|'
   build_script:
     - ./autogen.sh
-    - ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --without-interrupt-tests --with-topology --without-raster  --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf
+    - ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --with-topology --without-raster  --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf
     - service postgresql oneinitdb
     - service postgresql onestart
     - su postgres -c "createuser -s `whoami`"
diff --git a/ci/bessie/postgis_regress.sh b/ci/bessie/postgis_regress.sh
index 8add89303..eb7d75edd 100644
--- a/ci/bessie/postgis_regress.sh
+++ b/ci/bessie/postgis_regress.sh
@@ -5,7 +5,11 @@ set -e
 #BRANCH is passed in via jenkins which is set via webhook hook
 export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
 sh autogen.sh
-./configure --with-projdir=/usr/local --with-libiconv=/usr/local --without-interrupt-tests --with-library-minor-version --without-raster
+./configure \
+  --with-projdir=/usr/local \
+  --with-libiconv=/usr/local \
+  --with-library-minor-version \
+  --without-raster
 #make distclean
 make
 export PGUSER=postgres
diff --git a/ci/bessie32/postgis_regress.sh b/ci/bessie32/postgis_regress.sh
index 951698325..82d86a6de 100644
--- a/ci/bessie32/postgis_regress.sh
+++ b/ci/bessie32/postgis_regress.sh
@@ -9,7 +9,17 @@ export CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/g
 export CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc"
 sh autogen.sh
-./configure PKG_CONFIG=/usr/local/bin/pkgconf LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --without-interrupt-tests --with-topology --with-raster --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf --with-wagyu
+./configure \
+  PKG_CONFIG=/usr/local/bin/pkgconf \
+  LDFLAGS="-L/usr/local/lib" \
+  --with-libiconv-prefix=/usr/local \
+  --without-gui \
+  --with-topology \
+  --with-raster \
+  --with-sfcgal=/usr/local/bin/sfcgal-config \
+  --with-address-standardizer \
+  --with-protobuf \
+  --with-wagyu
 #make distclean
 make
diff --git a/ci/debbie/postgis_regress.sh b/ci/debbie/postgis_regress.sh
index 1aae9dd54..f2aa5ff17 100644
--- a/ci/debbie/postgis_regress.sh
+++ b/ci/debbie/postgis_regress.sh
@@ -63,7 +63,6 @@ fi
     --with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config \
     --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
     --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config \
-    --without-interrupt-tests \
     --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}  --with-library-minor-version
 make clean
 make
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index 0ee30f6da..48b5c30d1 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -16,7 +16,9 @@ SRCDIR=$PWD
 BUILDDIR=/tmp/postgis-build/${PGVER}
 mkdir -p "${BUILDDIR}"
 cd "${BUILDDIR}"
-${SRCDIR}/configure CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests --enable-lto
+${SRCDIR}/configure \
+  CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror" \
+  --enable-lto
 make -j
 # we should maybe wait for postgresql service to startup here...
diff --git a/ci/dronie/postgis_regress_alpine.sh b/ci/dronie/postgis_regress_alpine.sh
index 66a194fff..458aebb5f 100644
--- a/ci/dronie/postgis_regress_alpine.sh
+++ b/ci/dronie/postgis_regress_alpine.sh
@@ -8,7 +8,8 @@ su - postgres -c "export PGDATA=/var/lib/postgresql/data && pg_ctl -o '-F' -l /v
 export PGPORT=5432
 psql --version
 ./autogen.sh
-./configure CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
+./configure \
 make clean
 make -j
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 67ed5be23..7cbfae727 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -153,7 +153,6 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${I
   --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
   --with-gui --with-gettext=no \
   --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
   --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version
   #exit
 else
@@ -167,7 +166,6 @@ LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYP
   --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
 fi;
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 87fa159eb..163eba6a1 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -164,7 +164,6 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${I
   #exit
 else
@@ -177,7 +176,6 @@ LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYP
 fi;
diff --git a/configure.ac b/configure.ac
index 7c26b9382..b673cca3d 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1362,11 +1362,11 @@ AC_SUBST([TOPOLOGY])
 dnl ====================================
 dnl interrupt tests
-INTERRUPTTESTS="no"
+INTERRUPTTESTS="yes"
 AC_ARG_WITH([interrupt-tests],
-    [AS_HELP_STRING([--with-interrupt-tests],
-                    [Enable the interrupt tests])],
-    [INTERRUPTTESTS="yes"], [])
+    [AS_HELP_STRING([--without-interrupt-tests],
+                    [Disable the interrupt tests])],
+    [INTERRUPTTESTS="yes"], [INTERRUPTTEST="no"])
 if test "x$with_interrupt_tests" = "xno"; then
     INTERRUPTTESTS="no"
Summary of changes:
 .cirrus.yml                         |  2 +-
 ci/bessie/postgis_regress.sh        |  6 +++++-
 ci/bessie32/postgis_regress.sh      | 12 +++++++++++-
 ci/debbie/postgis_regress.sh        |  1 -
 ci/dronie/postgis_regress.sh        |  4 +++-
 ci/dronie/postgis_regress_alpine.sh |  3 ++-
 ci/winnie/build_postgis.sh          |  2 --
 ci/winnie/regress_postgis.sh        |  2 --
 configure.ac                        |  8 ++++----
 9 files changed, 26 insertions(+), 14 deletions(-)
hooks/post-receive
