[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-765-g5e61ca2e1
Fri May 5 12:07:54 PDT 2023
the project "PostGIS".
       via  5e61ca2e1e04ae438cc0200133a9ef1c8a89e97f (commit)
       via  43474d716f06ce9cd8e6c62c8878131552924c97 (commit)
       via  1a86c1b128e4b39f193f7be09da645708866bb12 (commit)
      from  c84141b87bdf7f310f1d41cd8d66fa57541b0021 (commit)
revisions in full, below.
commit 5e61ca2e1e04ae438cc0200133a9ef1c8a89e97f
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 5 21:07:35 2023 +0200
    Raise clien_min_messages to WARNING for interrupt tests
diff --git a/regress/core/interrupt.sql b/regress/core/interrupt.sql
index bc47d59f7..616e74fd7 100644
--- a/regress/core/interrupt.sql
+++ b/regress/core/interrupt.sql
@@ -1,5 +1,5 @@
 -- liblwgeom interruption
-set client_min_messages to NOTICE;
+set client_min_messages to WARNING;
 \i :regdir/utils/timecheck.sql
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index 6372f63a6..11f117a28 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -1,3 +1,5 @@
 CREATE TEMP TABLE _inputs AS
 SELECT 1::int as id, ST_Collect(g) g FROM (
  SELECT ST_MakeLine(
diff --git a/regress/core/interrupt_expected b/regress/core/interrupt_expected
index d6bbb771b..8b22c31aa 100644
--- a/regress/core/interrupt_expected
+++ b/regress/core/interrupt_expected
@@ -1,4 +1,3 @@
-NOTICE:  liblwgeom code interrupted
 ERROR:  canceling statement due to statement timeout
 segmentize interrupted on time
 1|LINESTRING(0 0,2 0,4 0)
commit 43474d716f06ce9cd8e6c62c8878131552924c97
Date:   Fri May 5 20:43:55 2023 +0200
    Use test.executor_slow_factor in timeout tests, reuse common code
index e5213094e..bc47d59f7 100644
@@ -1,37 +1,7 @@
-CREATE FUNCTION _timecheck(label text, tolerated interval) RETURNS text
-AS $$
-DECLARE
-  ret TEXT;
-  lap INTERVAL;
-BEGIN
-	-- We use now() here to get the time at the
-	-- start of the transaction, which started when
-	-- this function was called, so the earliest
-	-- posssible time
-  lap := now()-t FROM _time;
-  IF lap <= tolerated THEN
-		ret := format(
-			'%s interrupted on time',
-			label
-  ELSE
-		ret := format(
-			'%s interrupted late: %s (%s tolerated)',
-			label, lap, tolerated
-  END IF;
-  UPDATE _time SET t = clock_timestamp();
-  RETURN ret;
-END;
-$$ LANGUAGE 'plpgsql' VOLATILE;
-CREATE TEMPORARY TABLE _time AS SELECT now() t;
+\i :regdir/utils/timecheck.sql
 -- ST_Segmentize
@@ -40,6 +10,7 @@ CREATE TEMPORARY TABLE _time AS SELECT now() t;
 SET statement_timeout TO 100;
 -- would run for many seconds if uninterruptible...
 SELECT 'segmentize', ST_NPoints(ST_Segmentize(ST_MakeLine(ST_Point(4,39), ST_Point(1,41)), 1e-8));
 SELECT _timecheck('segmentize', '300ms');
 SET statement_timeout TO 0;
 -- Not affected by old timeout
index 47620324f..6372f63a6 100644
@@ -1,33 +1,3 @@
-AS $$
-DECLARE
-  ret TEXT;
-  lap INTERVAL;
-BEGIN
-	-- posssible time
-		ret := format(
-			label
-  ELSE
-		ret := format(
-  END IF;
-  RETURN ret;
-END;
  SELECT ST_MakeLine(
@@ -38,11 +8,7 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
  ) foo
--- Run ST_Buffer once to ensure the libary is loaded
--- before taking the start time
-SELECT NULL FROM ST_Buffer('POINT(0 0)'::geometry, 3, 1);
 -- ST_Buffer
diff --git a/regress/core/interrupt_relate.sql b/regress/core/interrupt_relate.sql
index 22f06afbc..547caa2bc 100644
--- a/regress/core/interrupt_relate.sql
+++ b/regress/core/interrupt_relate.sql
@@ -1,31 +1,5 @@
-AS $$
-DECLARE
-  ret TEXT;
-  lap INTERVAL;
-BEGIN
-		ret := format(
-			label
-  ELSE
-		ret := format(
-  END IF;
-  RETURN ret;
-END;
  SELECT ST_MakeLine(
@@ -36,7 +10,7 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
  ) foo
 -- IM9 based predicates
diff --git a/regress/utils/timecheck.sql b/regress/utils/timecheck.sql
new file mode 100644
index 000000000..a578acd3a
--- /dev/null
+++ b/regress/utils/timecheck.sql
@@ -0,0 +1,47 @@
+CREATE FUNCTION _timecheck(label text, tolerated interval) RETURNS text
+AS $$
+DECLARE
+  ret TEXT;
+  lap INTERVAL;
+	rec RECORD;
+BEGIN
+	-- We use now() here to get the time at the
+	-- start of the transaction, which started when
+	-- this function was called, so the earliest
+	-- posssible time
+  SELECT now()-t lap, sf slow_factor
+	FROM _time INTO rec;
+	RAISE DEBUG 'Requested tolerance: %', tolerated;
+	RAISE DEBUG 'Slow factor: %', rec.slow_factor;
+	tolerated := tolerated * rec.slow_factor;
+	RAISE DEBUG 'Resulting tolerance: %', tolerated;
+  IF rec.lap <= tolerated THEN
+		ret := format(
+			'%s interrupted on time',
+			label
+  ELSE
+		ret := format(
+			'%s interrupted late: %s (%s tolerated)',
+			label, rec.lap, tolerated
+  END IF;
+  UPDATE _time SET t = clock_timestamp();
+  RETURN ret;
+END;
+$$ LANGUAGE 'plpgsql' VOLATILE;
+CREATE TEMPORARY TABLE _time AS
+SELECT
+	now() t,
+	COALESCE(
+    current_setting('test.executor_slow_factor', true),
+    '1'
+  )::float8 sf;
commit 1a86c1b128e4b39f193f7be09da645708866bb12
Date:   Fri May 5 20:42:34 2023 +0200
    Make a test.executor_slow_factor setting available in regress db
    The slow factor will represent how slower a test executor is compared
    to the test executor expected by the developers writing the tests and
    tweaking expected times.
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 3f143f225..1c36e90b6 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -329,6 +329,28 @@ else
 my $libver = sql("select postgis_lib_version()");
+sub compute_executor_slow_factor
+    my $ms_to_fetch_full_version = sql(<<EOF
+        CREATE TEMP TABLE _start AS SELECT clock_timestamp() c;
+        SELECT FROM postgis_full_version();
+        SELECT EXTRACT(milliseconds FROM clock_timestamp()-c)
+             FROM _start;
+EOF
+    my $default_ms_to_fetch_full_version = 10;
+    my $test_executor_slow_factor = 1;
+    if ( $ms_to_fetch_full_version gt $default_ms_to_fetch_full_version )
+        $test_executor_slow_factor = $ms_to_fetch_full_version / $default_ms_to_fetch_full_version;
+    print "Executor slow factor: $test_executor_slow_factor ($ms_to_fetch_full_version ms to fetch full version)\n";
+    sql("ALTER DATABASE $DB SET test.executor_slow_factor = $test_executor_slow_factor");
+compute_executor_slow_factor;
 if ( ! $libver )
 	`dropdb $DB`;
Summary of changes:
 regress/core/interrupt.sql        | 35 +++--------------------------
 regress/core/interrupt_buffer.sql | 36 ++----------------------------
 regress/core/interrupt_expected   |  1 -
 regress/core/interrupt_relate.sql | 28 +----------------------
 regress/run_test.pl               | 22 ++++++++++++++++++
 regress/utils/timecheck.sql       | 47 +++++++++++++++++++++++++++++++++++++++
 6 files changed, 75 insertions(+), 94 deletions(-)
 create mode 100644 regress/utils/timecheck.sql
hooks/post-receive
